Numerical Analysis - Construction of a Poincare surface of section
This discussion focuses on constructing a Poincare surface of section for a Hamiltonian model influenced by the Henon-Heiles potential. The construction requires integrating the equations of motion using a symplectic algorithm to maintain the system's symplectic structure. The Poincare surface is a two-dimensional slice of phase space that visualizes periodic orbits and chaotic behavior. Participants are encouraged to consult numerical methods textbooks and online resources for specific algorithms and code examples.
  • Understanding of Hamiltonian mechanics
  • Familiarity with symplectic algorithms for numerical integration
  • Knowledge of phase space concepts
  • Experience with programming languages suitable for numerical analysis (e.g., Python, MATLAB)
  • Research symplectic integration methods for Hamiltonian systems
  • Explore numerical methods textbooks focusing on dynamical systems
  • Study existing implementations of Poincare surfaces in programming languages like Python
  • Investigate the Henon-Heiles potential and its applications in dynamical systems
Researchers, physicists, and students in the fields of dynamical systems and numerical analysis, particularly those working with Hamiltonian models and seeking to visualize system behavior through Poincare surfaces.
pendulum
(I am not sure whether I'm posting in the right forum. I apologize if I do)
Does anyone have an alrorithm or a code (in any language) that constructs a Poincare surface of section?
I want to do so for a Hamiltonian model: A mass under the influense of the Henon-Heiles potential. It has to include a symplectic algorithm for the integration of the equations of motion ,but that is no problem. The general idea of the P. surface, is what I'm having problem with.
So even a hint with what it's need to be done to construct it would be fine.
Thanks
Technology news on Phys.org
Dear fellow scientist,
Thank you for reaching out to the forum for assistance with constructing a Poincare surface of section. This is indeed the appropriate forum for such a question.
I am not able to provide a specific algorithm or code for this task, as it may vary depending on your specific Hamiltonian model and numerical approach. However, I can offer some general guidance and resources that may be helpful to you.
First, let's briefly discuss the concept of a Poincare surface of section. This is a two-dimensional slice of a higher-dimensional phase space that allows us to visualize the behavior of a dynamical system. In the case of a Hamiltonian model, this surface of section is often used to study the periodic orbits and chaotic behavior of the system.
To construct a Poincare surface of section, you will need to integrate the equations of motion for your Hamiltonian model using a symplectic algorithm. This ensures that the numerical solution preserves the symplectic structure of the system, which is essential for accurately capturing the dynamics.
Next, you will need to choose a specific plane in phase space to serve as your surface of section. This can be done by fixing certain variables in your Hamiltonian and plotting the remaining variables as a function of time. The intersection points of the trajectory with this plane will form the points on your Poincare surface.
As for the specific steps and code for constructing the surface, I recommend consulting with a numerical methods textbook or searching for online resources that provide step-by-step instructions for constructing a Poincare surface of section for a Hamiltonian model. You may also find it helpful to look at existing codes and algorithms for similar systems and adapt them to your specific model.
I hope this helps to point you in the right direction. Best of luck with your project!
  • · Replies 21 ·
