Where Does a Man Land When Jumping Inside a Moving Train?
  • Context: High School
  • Thread starter Thread starter sero
The discussion centers around the physics of a person jumping inside a moving train, specifically addressing where the person would land relative to their starting position in the boxcar. The scope includes concepts from classical mechanics, particularly Newton's laws of motion and considerations of momentum and air resistance.
  • One participant suggests that if the person jumps straight up, they will land in the same spot due to Newton's first law of motion and the conservation of momentum.
  • Another participant agrees that the jumper will land in the same spot but introduces the idea that air resistance may affect the outcome, potentially causing the jumper to land slightly behind their starting position.
  • A later reply emphasizes that the boxcar is closed, implying that the air inside moves with the train, which could affect the analysis of air resistance.
  • There is a discussion about the role of momentum and how it would be conserved in the absence of air, but the presence of air resistance complicates the situation.
Participants express differing views on the effect of air resistance, with some believing it will cause the jumper to land slightly behind their starting position, while others argue that the closed nature of the boxcar mitigates this effect. No consensus is reached on the final outcome.
Participants note the importance of considering air resistance and the closed environment of the boxcar, which may influence the jumper's trajectory and landing position. The discussion does not resolve the implications of these factors.
sero
If a train is going 35 mph and there's a dude standing in a boxcar and he jumps 2 feet in the air, where will he land? In the same spot, or ahead of or behind the spot he jumped from?
currently some friends and I are debating this. some say the same spot some say behind. I say the same spot due to Newtons 1st law of motion, and general relativity.
1. what is the anwser
2. what is the equation to solve it ?
If he jumps straight up, he will fall straight down...landing on the same spot in the boxcar.
No equations needed, but if you insist, the horizontal distance the jumper travels is:
[tex]d=v_0t[/tex]
This formula works in the frame of the ground or the boxcar. From the boxcar's viewpoint, [itex]v_0 = 0[/itex]; from the viewpoint of someone on the ground, [itex]v_0 = 35{mph}[/itex], the same speed as the boxcar itself.
cont
thanks Doc :smile:
Well there is a caveat. Before the guy jumps he's at rest with respect to the train. This means he shares the same forward speed the train does, relative to the ground, and has a forward momentum of his mass times that speed. When he jumps straight up, his momentum - and therefore his forward velocity - would be conserved if there was no air. And in that case he would still have the same speed as the train and would come down where he started.
But there is air resistance; some of his momentum is transferred to the air, and he loses a litle speed. So when he comes down he hasn't moved quite as far ahead relative to the ground as the train has, and he lands just a little behind his starting spot. Maybe only an inch or to, but iot would be measurable.
I don't think we need to consider coriolis force. Imagine the train is at the equator.
Originally posted by selfAdjoint
Well there is a caveat. ... When he jumps straight up, his momentum - and therefore his forward velocity - would be conserved if there was no air.
It's a boxcar, not a flatcar. :smile: Assume it's closed and the air is carried along.
9K
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 69 ·
18K
