Bernouilli's principle and downforces
  • Thread starter Thread starter OCCxlr8ed
    Principle
Downforce is generated by the pressure differential created by airflow over an object, as explained by Bernoulli's Principle. When air travels over a larger surface area beneath an object, it slows down, resulting in lower pressure compared to the higher pressure above the object. This pressure difference creates a net downward force. The angle of attack significantly influences the amount of downforce produced, as a greater angle increases the effective surface area and enhances the pressure differential.
  • Understanding of Bernoulli's Principle
  • Familiarity with the concept of pressure differentials
  • Knowledge of the equation for Lift and its components
  • Basic grasp of aerodynamics and angle of attack
  • Research the mathematical relationship between downforce and lift using the Lift equation
  • Study the effects of angle of attack on aerodynamic performance
  • Explore practical applications of downforce in motorsports and vehicle design
  • Learn about computational fluid dynamics (CFD) simulations for analyzing airflow
Aerodynamic engineers, motorsport designers, and physics students interested in the principles of fluid dynamics and their applications in vehicle performance.
OCCxlr8ed
Ok need some help here with downforce:
So far what i understand is that due to the different areas which air have to cover, when it goes over a surface with a larger area at the same time where the otherside has a smaller area the top will have a greater velocity and due to Bernoullis Principle it will have a decrease in pressure.
Vice-versa for the bottom side.
What i don't understand is how the force is applied?
From Wikipedia.org i found this image here:
http://upload.wikimedia.org/math/6/5/b/65b94fadeb8c96552b6242d37ed84efb.png
Which is the equation for determining Lift. Would downforce just be negative lift? Another two things which i don't understand in that equation is the "frontier of the domain? and the last three terms.
Is there a simple way of explaining downforce using Bernoulli's Principle and say the equation for Pressure; P=F/A ?
There is also the variable of "angle of attack" which i understand to be the angle at which the air "hits" the object.
Thanks.
Downforce is created by the difference in air pressure above and below an object. The air pressure below the object is greater than the air pressure above the object, resulting in a net downward force. This effect is achieved by increasing the area of the surface exposed to the air on the bottom of the object, creating a larger surface area for the air to pass over. As the air passes over the object and encounters the larger surface area, it is forced to slow down and therefore experiences a decrease in pressure. This decrease in pressure below the object creates a relative increase in pressure above the object, resulting in a net downward force. The angle of attack affects the magnitude of the downforce generated, as the angle of attack increases, the area of the bottom surface exposed to the air increases, resulting in a greater difference in air pressure and thus greater downforce.
  • · Replies 16 ·
