Understanding the Molecular Processes of Melting and Boiling in Matter
The discussion revolves around the molecular processes involved in melting and boiling, focusing on the thermal properties of matter. Participants explore the definitions and characteristics of different states of matter, as well as the intermolecular forces at play during phase transitions.
  • Some participants describe melting as the transition from solid to liquid and boiling as the transition from liquid to vapor, emphasizing the role of intermolecular forces.
  • One participant defines temperature as a measure of kinetic energy and discusses how energy transfer is essential for phase changes, noting that solids have less kinetic energy than required to overcome attractive forces.
  • Another participant explains that in solids, molecules are arranged in crystalline formations, while liquids allow for more movement among molecules, and gases have molecules that are largely free from each other.
  • A participant highlights the significance of energy transfer during state changes, using the analogy of a game of snooker to illustrate the energy required to initiate a phase transition.
  • There is mention of hydrogen bonding in water, explaining how it affects the density of ice compared to liquid water.
  • One participant expresses confusion about the processes of melting and sublimation, seeking clarification.
Participants present various definitions and explanations of melting and boiling, but there is no consensus on specific aspects, such as the nuances of sublimation or the detailed mechanisms of energy transfer. The discussion remains unresolved on these points.
Some definitions and concepts presented may depend on specific interpretations or contexts, and the discussion includes varying levels of detail regarding molecular interactions and energy transfer processes.
This discussion may be useful for individuals interested in the thermal properties of matter, phase transitions, and the molecular behavior of different states of matter.
skyjuices
Hi. I was wondering if any of you could help me with how you would describe what goes on during melting and boiling? the answer would involve the use of molecular structures as well as the intermolecular forces that occurs between them. this is under the topic of thermal properties of matter.
much thanks
In melting (the opposite of freezing) a material changes from a 'solid' state to a liquid state, and in boiling (opposite of condensation), a material changes from liquid to vapor.
In a solid state, many materials are crystalline with an ordered crystal structure or regular atomic lattice or repetitive molecular arrangement. Then there are amorphous structures like glass. Usually a single atom or molecule is bound to several others.
As a material is heated, the energy causes the bonds to be stretched (thermal expansion). At some point the atomic/molecular motion is so great that the bonds holding an atom/molecule in solid 'break'. Liquids still have some interconnection between atoms/molcules, whereas in the vapor phase, atoms/molecules are individually separated with relatively large distances (using the scale of atomic/molecular dimensions) between them.
I will try to explain what i can. I find that most problems in understanding stem from ambiguous definitions of certain concepts so ill try and define some terms first.
Temperature - A measure of the kinetic energy of matter, stemming from the human sense of heat originally. The more excited and energetic a substance is the greater its temperature will be, heat will flow or conduct across a potential gradient from areas of high energy to low. These are experimentally observable properties associated with the branch of science called thermodynamics.
Solid - A state of matter in which the molecules of a substance have less kinetic energy than the energy required to overcome the attractive forces between neighbouring molecules. They fall into crystaline formations, mostly vibrating.
Liquid - A state of matter in which the molecules of a substance have less kinetic energy than the energy required to overcome intermolecular forces, but sufficiently enrgetic that they can still move about freely to some extent, flowing as a fluid. Primarily molecules in a liquid move by rotations and vibrations.
Gas - Yet another observable state of matter in which the kinetic energy of the molecules are sufficient that most molecules are free from other molecules and are free to rotate, translate and vibrate.
Now when a substance, like water, undergoes a change of state, such as freezing, the molecules loose sufficient energy ( by collisions with a lower energy substance or some other energy transffer process ) that the intermolecular forces begin to take over the kinetic forces. The molecules can no longer overcome attractive forces, and contract and fall into and ordered lattice.
In the case of water, Hydrogen bonding is strong ( one of the intermolecular forces that is observed between hydrogen and other strongly electornegative atoms ) and such that when water actually freezes the molecules align in such a way that the density of Ice is less than that of water, and so ice floats.
The most important idea i think is that of energy transfer, in order for a state of matter to change energy must flow in or out of the system. Think of it as game of snooker if you like, the pack of red balls will only "break" if you hit them hard enough with the white. The kinetic energy you need to hit them with ( as measured by Temperature ) depends on a many factors, like the weight of the white ball and if your reds are magnetically attracted to each other..etc. These properties are different for different substances and so melting and boiling points are very much charateristics of a substance and have been so used to catogorise things.
An important aspect of changes of state is that of the energy required to cause the transition. This is a key point in finding a change of state, if you heat a bath of water its temperature will rise over time as it takes in the energy. However as it reahes the boiling point the temperature will stop rising for a short period (~100C). This is the boiling point, where the energy is now being transferred to the new mode as the molecules free themselves of intermolecular forces and begin to take off as a gas, after that the tempertaure of the gas will continue to rise.
A more in depth discussion could follow about Statistical Mechanics, Boltzmann, Kinetic Theory of gasses...I could go on for a long time...must stop typing...
hello sir... i was wondering to know about how the melting processes and sublimation process.
i have a little bit confiuse about this.
please help me!
  • · Replies 0 ·
  • · Replies 26 ·
21K
  • · Replies 16 ·
  • · Replies 83 ·
