Motorcycle Acceleration: Find Position, Velocity & Max Velocity
The problem involves the acceleration of a motorcycle described by the equation ax(t) = At - Bt², with specific constants provided. The motorcycle starts from rest at the origin, and participants are tasked with finding its position and velocity as functions of time, as well as determining the maximum velocity attained.
  • Participants discuss integrating the acceleration function to find velocity and position functions. There are questions about the constants of integration and whether to simplify the resulting equations. Some participants express confusion about whether to provide numerical answers or the functions themselves.
There is ongoing exploration of the integration process and the implications of initial conditions. Some participants have shared their derived equations, while others are questioning the correctness of their numerical answers versus the expected functional forms. Guidance has been offered regarding the treatment of constants of integration based on initial conditions.
Participants are navigating the requirements of their homework platform, which appears to expect specific formats for answers. There is mention of confusion regarding whether to submit functions or numerical values, as well as concerns about the accuracy of their calculations based on the problem's requirements.
Musicman
The acceleration of a motorcycle is given by ax(t) = At - Bt2, where A = 1.70 m/s3 and B = 0.170 m/s4. The motorcycle is at rest at the origin at time t = 0.
(a) Find its position as a function of time t.
Find its velocity as a function of time t.
b. Calculate the max velocity it attains. I already calculated the max velocity it attains which is 28.33 m/s.
Hi there musicman and welcome to PF,
What are your thoughts on this question? Would you mind posting what you have attempted thus far?
For the first question it looks like you are just supposed to integrate and sketch some graphs, but, as Hootenanny has already asked, what have you done so far?
ok i got:
v - v' = integral(At - Bt^2)dt
v = (1/2)At^2 - (1/3)Bt^3 + v'
x - x' = integral( v dt )
x = (1/6)At^3 - (1/12)Bt^4 + v't + x'
Musicman said:
ok i got:
That's correct, as the motocycle starts from rest your v' or constant of integration drops out.
This is also correct, again as your motocycle begins from rest at the origin your terms v' and x' drop out.
so would i write those exact functions in the space provided? or solve for an answer? and do i leave the apostrophes after the variables or no
Well, they can be simplified a bit, but will your tutor accept unsimplified answers? As a said before, the v', v't and x' terms drop out because of the intial conditions imposed by the question;
yea, they got to be simplified, thanks for the help.
Have you attempted to simplify them? How are you getting on with your second question?
v = (1/2)At^2 - (1/3)Bt^3 + v' was this the one as position as a function of time or velocity? the velocity right? because x is displacement
This is a function of velocity, this is a result of integrating acceleration.
ok right after it says find its velocity as a funtion of time it says (m/s) after the blank, so are they askign for a number or just the equation v=(1/2)At^2-(1/3)Bt^3...and isn't it ok for me to take off the +v' sicne it is zero?
Is a function a number of an equation?:wink:
Yes, in fact you should do as I have said on numerous occasions previously.
i wrote an actual number for position as a function of time and velocity as a function of time and got it wrong
Damn webassign homework . Sorry, I'm not getting at you. What exactly did you write?
13.12 m for the position as a function of time and 17.34 m/s as the velocity as a function of time.
Where did you get those numbers from? There is no way you can calculate them; besides the question asks for a function, not a numerical answer.
  • · Replies 19 ·
  • · Replies 26 ·
