Why is the normal used as a reference for angles in physics and math?
  • Thread starter Thread starter Aladin
    Normal
The discussion revolves around the use of the normal line as a reference for measuring angles in physics and mathematics, particularly in the context of light transmission and refraction at interfaces between different media.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the rationale behind using the normal as a reference, questioning how angles would be measured without it, especially on curved surfaces. They discuss the implications of using the normal in mathematical formulations and its historical context in solving refraction problems.
The discussion is active with participants providing insights into the significance of the normal in simplifying mathematical descriptions of physical phenomena. There is an exploration of different perspectives on the necessity of the normal in measuring angles and its relationship to light behavior.
Some participants reference historical approaches to refraction problems and the evolution of mathematical techniques in physics, indicating a broader context of inquiry into the subject.
Aladin
Please explain with another simple example
If you didn't, how would you measure i or r?
What would you do in the case of a curved surface?
The normal, which is perpendicular to the plane forming the interface between media (e.g. solid and gas), is simply a reference. The maximum transmission of light comes when the beam (photons) is parallel with the normal.
The normal is indeed a reference =) We need the normal (as what Astronuc said, perpendicular to the plane) to measure indexes .
When we develop the maths to describe the physics we try to make the maths as simple as possible. So the theory dictated that if we use the normal to the interface between the two media the maths will be much easier and natural to the real situation. You can also see that, using the normal as the reference for the angles, when the incident angle is zero the refraction angle will also be zero, which makes the most sense doesn't it? Refraction problems were also initially solved with graphical techniques in which case the normal were used in the diagrams (seee history of Willebrord van Roijen Snell - also called Snellius).
  • · Replies 21 ·
