Thread Closed
Capacitors connected in series.
Share Thread Thread Tools
Jul4-06, 06:52 PM   #1
Suppose we have 3 capacitors, C1, C2, and C3.
If C1 is connected to a battery it's charge is 30.8 microC. C1 is disconnected and discharged.
If C1 and C2 are connected in series to the same battery, their charge is 23.1 microC. Both are disconnected and discharged.
If C1 and C3 are connected in series their charge is 25.2 microC. All 3 are disconnected and discharged.
Now, if all 3 are connected in series to the same what is the resulting charge?
Ive tried so many different ways using the formula for series capacitors and Q=CV and Ive had no luck solving this problem.
There must be some rule (or trick) Im missing involving combing C12 and C13 that im completely missing. Can anyone offer any insight into solving this problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jul4-06, 07:02 PM   #2
what do you mean treid all sorts of ways using the series capacitors and Q=VC?
did you use [tex]\frac{1}{C_{eq}}=\frac{1}{C_1}+\frac{1}{C_2}[/tex]?
did you get all the three equations?
(so you could calculate the forth)
write them here, lets see whats wrong with them.
Jul4-06, 07:07 PM   #3
Well you would have
and
[tex]\frac{1}{C_{eq}}=\frac{1}{C_1}+\frac{1}{C_3}[/tex]
and finally
[tex]\frac{1}{C_{eq}}=\frac{1}{C_1}+\frac{1}{C_2}+\frac{1}{C_3}[/tex]
but how could you find the final charge without using a voltage?
Jul4-06, 07:25 PM   #4
right, so you got [tex]30.8*10^{-6}=C_1V[/tex]
and [tex]23.1*10^{-6}=C_{eq_1}V[/tex]
and [tex]25.2*10^{-6}=C_{eq_2}V[/tex]
you should be able to find [tex]C_1[/tex], [tex]C_2[/tex], and [tex]C_3[/tex] with these equations (they all depend on the voltage, but because the fourth eq. should use the same voltage, it cancels out...)
Thread Closed
Thread Tools
Similar Threads for: Capacitors connected in series.
Thread Forum Replies
A 9.0 μF and 4.0 μF capacitors are connected in parallel.... Introductory Physics Homework 3
Three capacitors connected to a battery Introductory Physics Homework 1
Resistor connected in series with a capacitor? Introductory Physics Homework 4
question about wires connected in series..... Introductory Physics Homework 3
