| Thread Closed |
numberator or denometer?? |
Share Thread | Thread Tools |
| Jul5-06, 05:52 PM | #1 |
good lord. im working on a lesson about instruments. and the the formula has a bunch of different fractions (eg/ tension fraction, length fraction, density fraction, etc.)
so they have one list of the "initial conditions" and then the other list of "final conditions". and there seems to be no logic for the putting the initial or final conditions into the fractions. like on question it'll suggest "since an increase in density results in a decrease in frequency, the density fraction will have the smaller density in the numerator" and then on another question "since a decrease in density results in an increase in frequency, the density fraction will have a larger density in the numerator" ~Amy |
| Jul5-06, 09:29 PM | #2 |
Recognitions:
AM |
| Jul6-06, 11:54 AM | #3 |
so if the initial conditions are:
fi = 147 Hz Fi = 289 N di = 1.40 mm li = 60 cm and then one of the questions says "find the final frequency (ff) if the tension (Fi) is reduced to 196N". whats the numerator, 289N or 196N? so i'd go 147Hz * (289/196)? or 147 * (196/289)? ~Amy |
| Jul6-06, 12:01 PM | #4 |
Recognitions:
numberator or denometer??[tex] f_n = { n \over 2L} {\sqrt {T \over \mu}} [/tex] right?? Let's say "A" refers to the initial values and "B" refers to the final values . Then write the equation for the initial values and the equation for the final and take the ratio of the two equations: [tex] {f_A \over f_B} = { n_A \over n_B} {L_B \over L_A} {\sqrt { T_A \over T_B}} {\sqrt {\mu_B \over \mu_A}} [/tex] If everything is kept the same except for the tension which is changed, then all the ratios give one except for the ratio with tensions so that gives [tex] {f_A \over f_B} = {\sqrt { T_A \over T_B}} [/tex] Hope this makes sense Patrick |
| Jul6-06, 12:10 PM | #5 |
hi Patrick
thanks, but im not sure what you mean i just need to know whats the numerator, 196 or 289. ~Amy |
| Jul6-06, 12:17 PM | #6 |
Recognitions:
(I am assuming that all the other variables are kept the same (same harmonic, same length, same linea mass density). (I showed you all the steps so that you could do any problem of that type. For example if it woul dbe the length that would be changed while keeping the same tension... or changing both the tension an dthe length, etc) Patrick |
| Jul6-06, 12:21 PM | #7 |
update: i think i figured it out. according to my book "a decreased force = a decreased frequency"
so they only way to come up with a decreased frequency answer is to the the 196N as the numerator. so my answer ended up being 99.695 Hz ~Amy |
| Jul6-06, 12:26 PM | #8 |
Patrick, i think i see what you're saying now. but in my workbook it's different. for example, the Ta and Tb switch numerators/denometors depending on the question. each question is different and they dont follow a pattern.
~Amy |
| Jul6-06, 12:26 PM | #9 |
Recognitions:
If it is, then you answer is wrong. I gave you all the steps to get t he correct answer but I don't know if you paid any attention to what I wrote. In any case, everything is spelled out clearly in my previous posts so I won't add anything else. Best luck. Patrick |
| Jul6-06, 12:30 PM | #10 |
Recognitions:
From the very first equation it should be clear that an increase of tension gives an increase of frequency, an increase of length gives a decrease of frequency and so on. But that's not enough to do calculation, you need to know how things depend on each other. For example the frequency is proportional to the *square root* of the tension, not to th etension itself (which is what you assumed when you got an answer of 99 Hz). The formula with the ratios I gave will solve *any* problem, even those where *two* variables or more are varied. Patrick |
| Jul6-06, 12:31 PM | #11 |
nevermind my prior post about 99Hz. i forgot to square root it.
so the correct answer should be 12,75 Hz? ~Amy |
| Jul6-06, 12:35 PM | #12 |
Recognitions:
In any case, that's not right |
| Jul6-06, 12:41 PM | #13 |
Recognitions:
| Jul6-06, 12:49 PM | #14 |
Patrick
im looking over all the sample questions in my workbook, and they all have the final tension (Tb) (in newtons) as the numerator.. ~Amy |
| Jul6-06, 12:53 PM | #15 |
~Amy |
| Jul6-06, 01:57 PM | #16 |
according to what i've pieced together, the equation for everything is:
ff = fi * (a square rooted tension fraction) * (a length fraction) * (a dimeter fraction) * (a density fraction) so ff = fi * (Ff/Fi square rooted) * (li/lf square rooted) * (di/df) * (pi/pf square rooted). sorry for aggravating you, but my workbook is contradicting your formula. ~Amy |
| Jul6-06, 04:14 PM | #17 |
Recognitions:
Show me how you got this from my equation? If you read my post #4 and my post #6, I gave all the numbers (I even identified all the variables) and the formula. You just have to plug in. Patrick |
| Thread Closed |
| Thread Tools | |
Similar Threads for: numberator or denometer??
| How to rationalize the numberator? | General Math | 9 | ||
| numberator or denometer?? | Introductory Physics Homework | 1 | ||
