What is the density of the Sun's surface?
The discussion revolves around the density of the Sun's surface, particularly focusing on the photosphere and its characteristics. Participants explore definitions of the Sun's surface, the implications of optical depth, and the varying densities within different layers of the Sun.
  • Some participants question how well-defined the Sun's surface is, noting its gaseous nature and the transition from transparent to opaque.
  • There is mention of the Sun's core density being approximately 150 g/cm³, but uncertainty exists regarding the surface density.
  • One participant references the SOHO site, indicating that the plasma near the surface is tenuous and gaseous, becoming denser towards the core.
  • Another participant provides links to various resources that discuss particle density in the photosphere and the mass densities of the Sun's layers, though they express uncertainty about the reliability of these sources.
  • Definitions of the Sun's surface vary, with some suggesting it is defined by local thermodynamic equilibrium (LTE) and the conditions for hydrogen atoms to collide sufficiently to reach thermal equilibrium.
  • Participants discuss the concept of optical depth, with one stating that the surface is typically defined at an optical depth of 1, involving the Rosseland mean opacity and density.
  • There is a suggestion that the point where the photon mean free path reaches infinity could be considered the surface, though this is noted as a simplification.
  • One participant describes the photosphere as a very thin layer, approximately 500 km thick, with a density much lower than that of air at sea level, suggesting it is akin to a good vacuum.
Participants express multiple competing views regarding the definition of the Sun's surface and the density at that surface. The discussion remains unresolved, with no consensus on a specific density value.
Limitations include varying definitions of the Sun's surface, dependence on the interpretation of optical depth, and the reliability of referenced sources regarding density values.
DaveC426913
2025 Award
I was looking at the http://antwrp.gsfc.nasa.gov/apod/ap060710.html" and marvelled how well-defined the Sun's surface is. I know about coronae and such, but still, it looks almost solid (though I know it's entirely gaseous).
How well-defined is the surface? Does it go from transparent to opaque over a short distance?
A bit of Googling has revealed that the Sun's core density is about 150g/cm^3, but what is the density at the surface?
Astronomy news on Phys.org
I wonder if one can calculate the density at the surface which so much "random" activity there. SOHO's site simply says...
This plasma is tenuous and gaseous near the surface, but gets denser down towards the Sun's fusion core.
http://sohowww.nascom.nasa.gov/explore/sun101.html
This Wikipedia article has some values for particle density in the photosphere and atmosphere of the sun (reliability uncertain).
http://en.wikipedia.org/wiki/Structure_of_the_Sun#Photosphere
This page has mass densities for layers of the sun.
http://solar-center.stanford.edu/vitalstats.html
Gravitational Energy of the Sun explains 'Coronal Heating'
http://www.plasmaphysics.org.uk/research/sun.htm
A profile of the sun's layers - little more than half-way down the page.
http://ircamera.as.arizona.edu/astr_250/Lectures/Lecture_12.htm
sun modeling
for theoretical work there are several operational definitions of the suns surface depending on what qualities you are interested in. The concept of local thermodynamic equilibrium LTE comes into play a lot. If you want to calculate the spectrum from the different ionization states of Hydrogen for example, a layer of the sun should be defined as the thickness that is needed for the H atoms in that layer to collide often enough that they can reach the same temperature. If you go out far enough the layer thickness you need will be too large and you can say you've reached the edge of the sun.
The 'surface' is usually defined as optical depth of 1 where optical depth is given by
[tex] \tau = \int_0^s \kappa \rho ds[/tex]
where [tex]\kappa[/tex] is the Rosseland mean opacity, and [tex]\rho[/tex] is the density and s is the path inward from where the density is "zero".
...so the answer is... :frown:
Complicated :biggrin: .
Simplest way to say is the point where the photon mean free path reaches out to infinity (not technically right, but that takes less typing that explaining in even more detail). So its the lowest point where the photons on average, escape to infinity without being scattered. Sorta.
So... the answer is...
the density a the surface of the Sun is _____
The visible surface of the sun (i.e. the region of the sun from where we get most of the light is called the photosphere. This layer is very thin, only about 500 km thick as compared to the radius of the sun of 700,000 km. The density of the photosphere is very, very low, about 0.1% of the density of air at sea level on earth. We would call that kind of density a good vacuum and is much less than the density of wood. [The density of air at sea level is 0.0013 gm per cubic cm].
http://www.madsci.org/posts/archives/may2001/988762969.As.r.html
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 0 ·
