Pressure of stagnant fluid volume in rotating cylinders
The discussion revolves around modeling the pressure of a fluid in a rotating cylinder system, specifically focusing on a high-speed rotating shaft and the stagnant fluid volume surrounding it. Participants explore laminar flow models, the implications of Reynolds and Taylor numbers, and the behavior of the fluid under these conditions.
  • One participant seeks a simple laminar flow model to describe pressure variations in a fluid surrounding a rotating shaft, noting the complexity introduced by Taylor vortices.
  • Another participant emphasizes that the assumption of laminar flow is contingent on the Reynolds number and the Taylor number, suggesting that flow stability can be compromised at higher values.
  • A participant mentions that the surrounding fluid is not stagnant but is influenced by viscous momentum transport, challenging the initial assumption of stagnation.
  • Discussion includes the need for boundary conditions and the relationship between azimuthal velocity and the linear velocity of the rotating shaft.
  • One participant reports high Reynolds numbers in their calculations, leading to concerns about the validity of the laminar flow model and the potential for instability.
  • Another participant questions the type of fluid being used and its practicality at high rotational speeds, seeking clarification on the gap between the shaft and housing.
  • Participants mention specific equations and methodologies from a fluid dynamics textbook, indicating ongoing calculations and the use of computational fluid dynamics (CFD) for further analysis.
Participants express differing views on the nature of the fluid flow, with some asserting that the fluid is not stagnant while others maintain the initial premise. There is no consensus on the applicability of the laminar flow model given the high Reynolds numbers discussed.
Participants note that the assumptions made regarding laminarity and flow stability are critical and depend on specific parameters like Reynolds and Taylor numbers. The discussion highlights the complexity of fluid behavior in rotating systems, with unresolved mathematical steps and varying interpretations of flow conditions.
RedCoat999
I have a high speed rotating shaft (~30,000 rpm). Outside the shaft I have a relatively stagnant volume of fluid surrounded by a non-rotating cylinder (housing).
I am looking to find a 'simple' laminar flow model to describe the pressure of the fluid fat any point radially from the OD of the rotating shaft to the ID of the non-rotating housing wall. I have researched online and found many references to Taylor vortices and the like, but this is too high-level.
Thank you in advance.
The simplicity is proportional to the assumptions you make.
The assumption of laminarity depends on how large is your Reynolds number, which should be defined upon the inner linear velocity and the gap between cylinders. Turns out to be that the laminar solution becomes unstable depending how large is the so-called Taylor Number. For some Taylor Number a bifurcation appears and Taylor cells or Taylor Vortices can be seen in laboratory. The flow is no longer laminar and the assumption of no radial and no vertical velocity is no longer valid.
The easiest model is the viscous model. Assuming low Reynolds numbers and low Taylors numbers, you only have azimuthal component of the velocity. The equations of motion are reduced to the radial laplacian of the azimuthal component to be zero, and the radial gradient of pressure to be compensated by the centrifugal force. Such a solution is as I said unstable for large Taylor numbers.
PS: the surrounding fluid is not stagnant at all. It is moving because of the viscous transport of momentum, and for long times after the start, the viscous effect has reached the whole fluid in the gap.
Clausius, I got to tell you something. Even when it's a subject that I know nothing about (as with most of your answers), it is an absolute delight to read your posts. You, my friend, are elegant.
Taylor Instability
:blushing: That's the nicest thing that a friend has told me in a long, long time (let's not talk about girls).
Get a room you two.
Nice post Clausius.
FredGarvin said:
Get a room you two.
I don't think that's what he meant by not talking about girls. :-p
By that, I would take one to mean, no axial flow.
As Clausius indicated, the fluid is from from stagnant, but there will be boundary conditions, and a radially dependent azimuthal velocity component between the inner rotating cylinder and the stagnant one.
In velocity of the fluid on the inner surface must be equal to the linear velocity of the rotating shaft, i.e. [itex]v_{\theta}[/itex](r) = [itex]\omega[/itex]R1, r = R1, where [itex]\omega[/itex] is the angular velocity of the rotating cyliner and R1 is the radius. At the outer surface, [itex]v_{\theta}(r)[/itex] = 0, for r = R2. Then one solves the momentum equation for the fluid.
FredGarvin said:
Get a room you two.
Nice post Clausius.
Yeah, is Holidays Inn ok with you Danger? :smile:
I forgot to say that here the Taylor Number is just the square of the Reynolds.
I prefer Super-8, but I'm too old to be picky. :biggrin:
Thank you Astronuc and Clausius2 for your responses. Since I am more of a nuts and bolts engineer can either of you point me to some equations for the 'simple' model (laminar flow) to solve for pressure over the radius?
Thanks again.
I have found some equations on page 111, §3-2.3 of "Viscous Fluid Flow", 2nd Ed. Following their methodology and using MathCad to cheat at the inegration! I am getting the pressure dropping off very quickly (and going negative) from the non-rotating OD (housing). The Reynolds numbers are very high (100000 near the OD, and over 1 million at the OD). I am thinking I need to bug my busy CFD buddies to get a solution.
The pressure must increase radially, and it will be negative depending on the reference pressure you chose.
I don't have any information to work out the Reynolds number, but if it is 100000 according to your calculations, simply your viscous flow solution does not exist on reality, it would become unstable before reaching any steady state.
Try to do the same with fully turbulent flow...may be it hasn't been done ever (congratulations!)
What kind of fluid? Gas (air) or liquid?
At 30,000 rpm, I don't imagine liquid would be practical.
Also what is the gap between the OD of the shaft and ID of housing?
The liquid has a density of ~50 lb/ft^3 and viscosity of ~1.5 cs. The gap between the shaft and the housing is ~0.5 inch
  • · Replies 26 ·
  • · Replies 45 ·
  • · Replies 33 ·
