| Thread Closed |
Complex numbers. Imaginary part |
Share Thread | Thread Tools |
| Jan14-04, 01:12 PM | #1 |
z1 = x + iy
z2 = x - iy (Complex conjugate) Find: Im (1/z1) This is what I have tried to do: (1) z1*z2 = x^2 + y^2 (2) z2 / (x^2 + y^2) = 1 / z1 The answer is: -y / (x^2 + y^2) = Im (1 / z1) So my question is: Can I change z2 to Im (z2) and z1 to Im (z1) in equation (2)? |
| Jan14-04, 01:17 PM | #2 |
They want the coefficient of i or Im(1/z)
i.e [tex]\frac{1}{x+iy}[/tex] What was/are ur thoughts???[8)] |
| Jan14-04, 01:24 PM | #3 |
oops, read another post and found that it would be wise to post my work. And i reckoned that no-one would have had the time to reply so i just edited my post.
But do my new post clarify anything? |
| Jan14-04, 01:42 PM | #4 |
No u can't change them that ways. It will defy all the properties of complex number
| Jan14-04, 03:07 PM | #5 |
fannemel,
I think your work is correct. Because, if 2 numbers are equal, then their imaginary parts are equal. |
| Jan14-04, 03:28 PM | #6 |
Yes, fannemel, you are entirely correct. Given z = x + iy, Im(1/z) is indeed -y / (x^2 + y^2).
- Warren |
| Jan15-04, 04:59 AM | #7 |
[tex]\frac{Im_{z2}}{x^2 + y^2} = \frac{1}{Im_{z1}}[/tex] Which is not true |
| Jan15-04, 07:24 AM | #8 |
what about
[tex]\frac{Im_{z2}}{x^2 + y^2} = Im [\frac{1}{z1}][/tex] Would that be any better? For me that would equal: [tex]{\frac{-y}{x^2 + y^2} = Im [\frac{1}{z1}][/tex] since [tex]Im_{z2} = -y [/tex] |
| Jan17-04, 03:34 AM | #9 |
Yes that is absolutely correct. You get the imaginary part of the reciprocal of z1, not z1
| Jan17-04, 09:07 AM | #10 |
In general you cannot get the imaginary part of a number computed by a formula just by replacing each number in the formula by its imaginary part. It would be far better for you to replace [tex]z_1[/tex] and [tex]z_2[/tex] by x+iy and x-iy right from the start: [tex]\frac{1}{z_1}= \frac{1}{x+iy}[/tex]. Now multiply both numerator and denominator by x- iy to get [tex]\frac{(1)(x- iy)}{(x+iy)(x-iy)}= \frac{x- iy}{x^2+ y^2}= \(\frac{x}{x^2+y^2}\)-\(\frac{y}{x^2+y^2}\)i[/tex] so that it is obvious that the real part is [tex]\frac{x}{x^2+y^2}[/tex] and the imaginary part is [tex]\frac{-y}{x^2+y^2}[/tex]. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Complex numbers. Imaginary part
| A new set of numbers as a z-Axis to imaginary and real numbers? | General Math | 9 | ||
| identify the imaginary part | Precalculus Mathematics Homework | 4 | ||
| are complex numbers part of the "real" world | General Discussion | 8 | ||
| Help with imaginary and complex numbers | Introductory Physics Homework | 1 | ||
| Imaginary part in Ds | General Physics | 21 | ||
