How Do You Calculate the Original Volume of Gas After Pressure Change?
  • Thread starter Thread starter hecate
    Gas Volume
The original volume of gas under a pressure change from 720 mmHg to 760 mmHg, with a final volume of 580 mL, can be calculated using the combined gas law. The formula used is P1V1 = P2V2, where P1 is 720 mmHg, P2 is 760 mmHg, and V2 is 580 mL. By rearranging the formula to solve for V1, the calculation yields an original volume of 760 mL. This method effectively demonstrates the relationship between pressure and volume in gas laws.
  • Understanding of the combined gas law
  • Familiarity with pressure units (mmHg)
  • Basic algebra for solving equations
  • Knowledge of gas behavior under changing conditions
  • Study the ideal gas law and its applications
  • Learn about gas law derivations and real-world applications
  • Explore unit conversions between pressure and volume
  • Investigate the effects of temperature on gas volume
Chemistry students, physics enthusiasts, and professionals in fields requiring gas behavior analysis will benefit from this discussion.
hecate
can anyone tell me the steps to do this problem?
You are given a gas that you measure under a pressure of 720 mmHg. When the pressure is changed to 760 mmHg, the volume becomes 580 mL. What was the original volume of the gas?
I don't know how to do this problem. thanx!
Its this simple ratio:
[tex]\frac{P_{1}}{V_{1}} = \frac{P_{2}}{V_{2}}[/tex]
so to find [tex]V_{1}[/tex]
[tex]V_{1} = \frac {P_{1}V_{2}}{P_{2}}[/tex]
Sure, I'd be happy to help you with this problem! Here are the steps to solve it:
1. Write down the given information: pressure 1 (P1) = 720 mmHg, pressure 2 (P2) = 760 mmHg, volume 2 (V2) = 580 mL.
2. Use the combined gas law formula: P1V1/T1 = P2V2/T2, where P1 and P2 are the pressures, V1 and V2 are the volumes, and T1 and T2 are the temperatures.
3. Since the temperature is constant in this problem, we can remove it from the equation. This leaves us with P1V1 = P2V2.
4. Plug in the given values: (720 mmHg)(V1) = (760 mmHg)(580 mL).
5. Solve for V1 by dividing both sides by 720 mmHg: V1 = (760 mmHg)(580 mL) / 720 mmHg.
6. Use unit conversion to convert mmHg to mL: 1 mmHg = 1 mL, so the units cancel out and we are left with V1 = 760 mL.
7. Therefore, the original volume of the gas was 760 mL. I hope this helps! Let me know if you have any other questions.
