How quasars are related to black holes in galaxies?
The discussion revolves around the nature of quasars, their relationship with supermassive black holes (SMBHs) in galaxies, and the mechanisms behind their luminosity and feeding processes. Participants explore various aspects of quasars, including their distance from Earth, their formation, and the evolutionary theories related to active galactic nuclei (AGN).
  • Some participants propose that quasars are powered by SMBHs that are accreting matter, leading to significant light emission, while noting that not all SMBHs are associated with quasars.
  • There is a suggestion that quasars are found at large distances due to the higher accretion rates of SMBHs in the early universe, although the exact reasons for this phenomenon remain unclear.
  • Participants express confusion regarding the definition of quasars and the structure of the accretion disks from which they derive their energy.
  • One participant describes the accretion disk as a disk-shaped area of matter that feeds the SMBH, but the exact mechanisms of how matter reaches the quasar are still not fully understood.
  • There is a discussion about the evolutionary paths of AGN, with one participant referencing a theory that categorizes different types of AGN and their potential evolution into various galaxy types.
  • Some participants correct earlier claims about the prevalence of SMBHs in galaxies, noting that not all galaxies host SMBHs, particularly those without bulges.
  • Uncertainty is expressed regarding the mechanisms that initiate and halt the feeding process of SMBHs, with some participants suggesting that the feeding stops when the surrounding matter is depleted.
Participants generally agree on the connection between quasars and SMBHs, but there are multiple competing views regarding the mechanisms of accretion and the evolutionary theories of AGN. The discussion remains unresolved on several points, particularly concerning the specifics of how matter is drawn to quasars and the evolutionary pathways of different AGN types.
Limitations include the lack of consensus on the mechanisms of matter accretion and the evolutionary theories presented, as well as varying definitions and understandings of quasars among participants.
blumfeld0
Can anyone point me to some good links about the our current understanding of quasars-in particular why they are so far away? and also how they are related to black holes in galaxies?
thanks
Astronomy news on Phys.org
thanks
I have another question to add to blumfeld's question - What exactly are quasars? I'm very confused because I've read somewhat different explanations in different books...
Quasars are what we observe when a supermassive black hole (SMBH) at the center of a galaxy is accreting a lot of matter and, as a result, emitting a lot of light. We think all quasars are powered by SMBHs, but not all SMBHs power quasars. For example, the SMBH at our galaxy center does not power a quasar.
Quasars almost certainly accrete from a disk, which is made up of matter that somehow managed to dissipate enough energy and angular momentum to approach the supermassive black hole. The exact structure of these disks is still a mystery, but it likely varies from quasar to quasar.
Quasars are generally found at large distances (and therefore earlier times) because SMBHs were accreting more matter at earlier times in the universe. Quasar activity peaked when the universe was about a fifth of its current age. The reason is not known exactly, but it probably is explained by some combination of the growth of structure in the standard cosmological model (objects collapse more easily prior to dark energy domination), the growth of SMBHs (which can shine more brightly as they grow), and the general evolution of galaxies and galaxy clusters.
So what I understand is that - Quasars are flashes of light around the galactic centre. Am I right?
could you explain what do you mean by "disk"??
This is very interesting I must say :)
A disk of matter looks like this
http://www.urania.be/sterrenkunde/images/quasar.jpg
And it's basically what it sounds, a disk-shapped area full of matter, including atoms, planets, stars, etc.
As the SMBH consumes this matter, it will give off light.
Eventually the feeding stops, and that is thought to have something to do with the speed of the stars in the end of the disk and the size of the black hole itself.
And in case you are wondering, every galaxy, including ours, has its very own SMBH billions of times the mass of our sun. ;)
I'm not sure what this is supposed to mean. The mechanism by which matter is brought to the quasar is not yet understood.
Not quite every galaxy. SMBHs are generally found in bulges, so spirals without bulges (like M33) tend not to host an SMBH. The mass you quote is only seen in the largest of SMBHs, which are likely the ones that power quasars. By contrast, the Milky Way's black hole is only a few million solar masses.
Well, I'm not sure how up-to-date this is, but supposedly all spiral galaxies are supposed to have a black hole in their center which would start sucking up matter, giving off energy (creating a quasar), and growing larger in size.
Eventually, this "feeding" would stop once the black hole has pushed the disk of matter far enough from itself, and the black hole would just lie there somewhat dormant, like in our galaxy, so no more quasar then.
That's what I meant when I said the constant feeding stopped.
Feeding = Quasar.
Not feeding = our galaxy = no quasar.
Like I said, not sure how up to date this is, but I thought it was pretty recent. =)
You are right about every galaxy not having a SMBH, and I didn't know about our black being so "small" (this is somewhat disappointing). I stand corrected. :)
I don't disagree with your description of where quasar light comes from, I'm just saying that the mechanism by which this feeding starts (and subsequently stops) is still a mystery. Most likely, a quasar stops shining when it has already "consumed" the matter around it, but it's not clear how this matter got there in the first place.
So that means (from what you'll have been discussing) the whole process of feeding is gives rise to something we call Quasar, and its' basically just light produced from the process of feeding.
So have Black Holes been discovered finally? I'm not at all up-to-date on this knowledge about Black holes/SMBHs because...because.
Hehe - HELP friends!
I just read in a textbook of mine last night something I thought was very interesting. They postulated that certain AGN evolved into each galaxy type. That quasars/blazars became radio galaxies which became run of the mill ellipticals, and that QSOs became Seyfert Galaxies which evolved into ordinary spirals. This is of course an evolutionary path based on the categorization of the AGN as radio loud/quiet.
It was just a theory, but has there been any more work on this in recent times? Science always loves to unify, and this would be quite the unification.
  • · Replies 22 ·
