Understanding Violation of Causality: Explained by Reference Frames
  • Context: Graduate
  • Thread starter Thread starter David Laz
    Causality
The discussion revolves around the implications of faster-than-light (FTL) travel and information transfer on causality, particularly through the lens of reference frames. Participants explore theoretical frameworks, including wormholes and preferred frames, and their potential compatibility with relativity.
  • Some participants suggest that FTL travel could allow for scenarios where observers perceive events occurring in reverse chronological order, potentially enabling time travel.
  • There are references to theoretical constructs like wormholes that might permit FTL travel without violating causality, provided certain principles, such as a "censorship" principle, are upheld.
  • One participant raises concerns about the effectiveness of the censorship principle in preventing paradoxes associated with networks of wormholes that could allow for instantaneous communication across time.
  • Others mention that "preferred frame" theories, which contradict relativity, could theoretically allow FTL travel without causality violations, but these would require assumptions that challenge established physics.
  • Discussion includes the potential role of quantum vacuum fluctuations in destabilizing wormholes that might become time machines, although the analysis of such scenarios is noted to be speculative and uncertain.
  • Some participants express skepticism about the feasibility of experimental tests related to these concepts, indicating that they may remain theoretical for the foreseeable future.
Participants do not reach a consensus on the implications of FTL travel for causality, with multiple competing views and theoretical models presented. The discussion remains unresolved regarding the viability of the proposed frameworks and their compatibility with established physics.
Limitations include the speculative nature of the proposed theories, the dependence on unproven assumptions, and the unresolved status of mathematical and physical claims related to wormholes and FTL travel.
David Laz
I was having an argument with some of my friends last night and I needed to explain why faster than light travel or infomation traveling faster than c violates causality. Unfortunately I studied this a long time ago and don't quite remember. Could anyone give me a brief explanation why? I remember a demonstration involving reference frames but I can't for the life of me put it together now.
Thanks in advance.
David, perhaps you mean how it violates causality rather than why? The how is that if you can go faster than light, SOME inertial observers will see you moving back in time; putting your own movements together with reports from those observers you can send messages or travel into your own past. This can all be diagrammed on a space-time plot.
You might try reading through
http://sheol.org/throopw/tachyon-pistols.html
Note that there can be more to this issue. There are some rather far-out schemes (like wormholes) that might theoeretically allow FTL travel without violating causality (i.e. no closed time-like curves) that are also completely compatible with relativity.
The wormhole scheme requires a "censorship" principle which destroys wormholes that become time-machines in order to maintain causality. This is not quite as far out as it seems (though it's still pretty far out), because quantum vacuum fluctuations would tend to become infinite in a wormhole at the instant it becomes a time machine. This would tend to destroy the wormhole.
There are other "preferred frame" schemes that are incompatible with relativity that would allow FTL travel without violating causality. If you can go any distance in a short amount of time in "some preferred frame", you can jump out a far distance, then jump back, but you'll never get back to before you started. However, this requires some particular "preferred frame", something that would violate relativity.
The censorship principle would have to be pretty strong/weird, because it isn't sufficient to censor each wormhole separately. Assume relativity is valid and you can build a wormhole that permits instant communication with your pal, who is 1.1 light years away and moving away from you at 87% of c. You use it to send him the S&P index charts for the preceding year. He likewise can use another wormhole to send that info back to you instantly. But his "instant" is canted at 30 degrees to yours in spacetime and goes a year into your past. This only one of a potential infinity of schemes involving any number of third parties; how would a censorship principle prevent them from working?
Of course if you break the rules of relativity ("preferred frame") you don't have to obey the constraints of relativity.:devil:
Yep.
A serious reference on the issue is (which I've only read popularized summaries of) is:
Matt Visser. From Wormholes to Time Machines: Remarks on Hawking's Chronology Protection Conjecture. Physical Review D v47, n2, p554. 15-Jan-1993.
I don't think it addresses the network issue, specifically.
The basic idea is that "quantum vacuum fluctuations" build up along any closed time-like curve (CTC). This much is more or less expected.
The big issue - will these fluctuations be powerful enough to destroy any wormhole? Including any theoretically possible wormhole? Doing the analysis at all requires a lot of guessing, because we don't have a theory of quantum gravity.
Having networks of wormohles makes the problem even more difficult to analyze. I think there may be papers on the issue, even so. I've got a hazy recollection reading that the networks could be more robust than single wormholes, but I'm not sure where I read that.
It's almost enough to make one think that restricting space-time to a trivial topology might not be such a bad idea (there are some approaches that would do this automatically). Then we wouldn't have to worry about wormholes :-).
Anyway, all of this stuff is rather far out, in that I don't see experimental tests coming in any of our lifetimes. This includes testing the issue of whether or not space-time topology is trivial or not (at least by design, we can always hope we stumble across something). Though come to think of it, I think people are trying to address the global topology question by studying the CMB anisotropies, I'm just not sure if I believe this can really be convincing.
Thanks for the responses. :)
  • · Replies 21 ·
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 145 ·
20K
