| Thread Closed |
Kinetic energy and frames of refrence |
Share Thread | Thread Tools |
| Jul23-06, 03:48 PM | #1 |
Hi!
When we measure the Kinetic energy, which is the correct frame of reference that we must choose? Thanks
| Jul23-06, 04:06 PM | #2 |
Pete |
| Jul23-06, 04:49 PM | #3 |
Thank you
But I'm a little confused. For example. A car with mass M=1000kg Initially in rest with respect to the ground accelerates until reaching v=50m/s. Use a fuel that renders R=50 000J/kg (1kg of fuel becomes 50000 jouls) [tex]E=\Delta K=\frac{1}{2}Mv^2=mR[/tex] (m is the mass of fuel that the car spend) [tex]m=\frac{Mv^2}{2R}=25kg[/tex] But if we change the frame of reference (also inertial) the car spends different fuel What happens? |
| Jul23-06, 11:46 PM | #4 |
changing frame of reference does not chance anything. Your car is initially at rest v_i=0m/s and accelerates to v_f=50km/h=13.89m/s. that gives you the diffrence in kinetic energy \Delta K= 0.5M(v_f-v_i)^2.
If you are in a frame of refrence moving at 5m/s relative to the ground, the car is not initially at rest, but is moving with a speed v_i=-5m/s and accelerates to v_f=8.89m/s. Thus, the diffrence in kinetic energy is the same. (Remember to be consistent with your units, and transform km/h into m/s before you do your calulations - your value for m is wrong) |
| Jul24-06, 11:19 AM | #5 |
Thank you for you answer
![]() Sorry, I will change m/s instead of km/s. |
| Jul24-06, 11:56 AM | #6 |
Mentor
[tex]\Delta{KE} \ne \frac{1}{2}m (v_f - v_i)^2[/tex] Instead: [tex]\Delta{KE} = \frac{1}{2}m (v_f^2 - v_i^2)[/tex] Yes, the change in KE of the car does depend on the reference frame used; to understand what's going on, you need to consider the change in KE of everything, including the earth itself. Here's a post that might help: http://www.physicsforums.com/showpos...9&postcount=12 |
| Jul24-06, 12:01 PM | #7 |
Well, if we change of frame of reference by other that one moves to -5m/s relative to ground. The initial speed of the car in that frame of reference will be v_0=5m/s and the end v_f=55m/s
[tex]E=\Delta K=\frac{1}{2}Mv_f^2-\frac{1}{2}Mv_0^2=\frac{1}{2}M(v_f^2-v_0^2)=\frac{1}{2}M(55^2-5^2)=1.5\times 10^6 J[/tex] [tex]m_{fuel}=\frac{1.5\times 10^6 J}{R}=30kg[/tex] It spent different fuel. Kind regards ![]() Edit: Thanks Doc Al. I see that. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Kinetic energy and frames of refrence
| Conservation of Energy in different inertial frames | Classical Physics | 19 | ||
| Interaction Energy how does it transform between inertial frames? | Special & General Relativity | 3 | ||
| Energy of a photon in different frames. | Special & General Relativity | 29 | ||
| Energy and reference frames | Special & General Relativity | 10 | ||
| kinetic energy in frames of reference | General Physics | 1 | ||
