Understanding Vector Quantities and Projections: Answers to Common Questions
  • Thread starter Thread starter jlmac2001
    Couple
This discussion clarifies that every quantity with three components in three dimensions qualifies as a vector, as it possesses both magnitude and direction. A concrete example provided is a force vector with components of 10 N, 5 N, and 3 N in the x, y, and z directions, respectively. Additionally, the projection of a force vector F along a velocity vector v is determined using the dot product, which yields a scalar if the vectors are perpendicular. If the dot product results in a vector, the projection is not a scalar.
  • Understanding of vector definitions and properties
  • Familiarity with three-dimensional coordinate systems
  • Knowledge of the dot product operation
  • Basic concepts of force and velocity in physics
  • Study vector operations in three-dimensional space
  • Learn about the dot product and its applications in physics
  • Explore the concept of vector projections in detail
  • Investigate the relationship between force and velocity vectors
Students of physics, educators teaching vector analysis, and professionals in engineering fields who require a solid understanding of vector quantities and their projections.
jlmac2001
1. Is every quantity that has three components in three dimensions a vector? From the definition of a vector I think it is. If it isn't, can you give me an example?
2. How can you tell if the projection of a force vector F along the velocity vector v of a particle is a scalar?
It would be possible if it obeys vector law of addition
Consider a current flowing through junction which is attached to three dimension network, it will have magnitude in 3 direction.
But definitely current is a scalar quantity
Projection along v will be fcos(theta)
Now F.v=Fcos(theta)*v Therefore
Fcos(theta)= (F.v)/v which is clearly scalar
1. Yes, every quantity that has three components in three dimensions is a vector. This is because a vector is defined as a quantity that has both magnitude and direction. In three dimensions, we need three components (x, y, and z) to fully describe the direction of a vector. An example of a vector with three components could be a force acting on an object with a magnitude of 10 N in the x-direction, 5 N in the y-direction, and 3 N in the z-direction. This vector has both magnitude (10 N) and direction (in the x, y, and z directions), fulfilling the definition of a vector.
2. To determine if the projection of a force vector F along the velocity vector v is a scalar, we can use the dot product. The dot product of two vectors results in a scalar quantity. So, if the dot product of F and v is a scalar, then the projection of F onto v is also a scalar. This means that the force and velocity vectors are perpendicular to each other, resulting in a scalar projection. If the dot product results in a vector, then the projection is not a scalar and the force and velocity vectors are not perpendicular. In this case, the projection would be a vector.
  • · Replies 30 ·
