Solve Staircase Projectile Problem: Find the First Step Hit
  • Thread starter Thread starter asdf1
    Projectile
The problem involves a ball rolling off a staircase with a specified horizontal velocity and dimensions of the steps. Participants are exploring how to determine which step the ball will hit first based on its motion and the geometry of the staircase.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods, including trial and error to check each step sequentially. Some suggest analyzing the trajectory of the ball and when it intersects with the line connecting the edges of the steps. Others propose using equations of motion to relate horizontal and vertical components of the ball's path.
The discussion is active with multiple approaches being considered. Some participants have provided formulas and insights into the ball's motion, while others express curiosity about the reasoning behind these methods. There is no clear consensus, but several productive lines of inquiry are being explored.
Participants are working within the constraints of the problem as posed, including the dimensions of the steps and the initial conditions of the ball's motion. There is an emphasis on understanding the physical principles involved without arriving at a definitive solution yet.
asdf1
A ball rolls out from the top of the stair case, with a horizontal velocity of 5 ft/s. Each step is 8 inches wide and 8 inches long. Which step will the ball hit first?
My problem:
I'm stuck on how to handle the problem. Where do you start thinking?
You could try trial and error.
First, see if the ball will hit the first step.
If not, then see if the ball will hit the second step.
If not, then see if the ball will hit the third step.
Useful formulas:
[tex]t_{falling} = \sqrt{\frac{2h}{g}[/tex]
[tex]x_{max} = v_0\sqrt{\frac{2h}{g}[/tex]
Maybe there is a better method to solve the exercise. But that's the only one I see. Hope it helps! :wink:
See when the ball drops below the line joining the edges of the steps. It will hit the step that is immediately below the point where it crosses that line.
Keep in mind the ball falls in a parabolic motion
http://img148.imageshack.us/img148/580/stepssy0.png
wow... thanks! how'd you think of that?
let it fall on the nth step
v along x=5cos theta
n*8(length of the step)=vcostheta*t
here theta=0(thrown along the x axis)
similarly proceed in y direction and finally equate t in both the eqn
thank you very much!
10K
