Originally posted by marcus
To me, this does not sound like an explanation "in layman terms".
Something is in
layman terms when it does not require a background in math or physics to understand it. That description does not require a background in physics to understand it and it contains no math. It was the simplest explanation and the most precise that I know of in layman terms.
If I remember correctly, their explanation was to the effect that light does not experience any gravitational force at all, but simply travels along a geodesic (the analog of a straight line in curved space).
They are certainly entitled to their opinion. But I choose to describe things in what I believe to be a more precise manner.
marcus - You've referred to the article
The Concept of Mass, Lev B. Okun,
Physics Today, June 1989. Did you read that paper?
In that paper Okun used the expression for the gravitational force that I posted in the thread
SR and the earth, sun, and galaxy.. If you have this paper its Eq. (16) on page 51. Okun states
The so-called gravitational mass of the photon falling vertically toward Earth is, incidentally, given by E/c2. As you an see from equation 16, however, a horizontally moving photon ... is twice as heavy.
This of course means that he is speaking of the gravitational force on the photon.
Yes. Light does travel on a geodesic. There is no question about that. In fact any test particle (no charge, non-spinning etc.) which experiences only gravitational forces will move on a geodesic. In that sense it is incorrect to say that a particle in free-fall in a gravitational field experiences no gravitational force. To me that is like saying that a projectile fired from a battleship experiences no Coriolis force. Such a statement is highly inaccurate.
You're probably used to hearing inertial forces referred to as "fictituous forces." That is a very misleading name as has been pointed out in the physics literature. You can learn more about the Coriolis force and gravitational force as an inertial force in these lecture notes
http://www.whoi.edu/science/PO/people/jprice/class/aCt.pdf. . Note what the author says on this point
If we need to call attention to these special properties of the Coriolis force, then the usage Coriolis inertial force seems appropriate because it is free from the taint of unreality that goes with ’virtual force, fictitious correction force’, etc., and because it gives at least a hint at the origin of the Coriolis force.
Please take note that these notes are by no stretch of the imagination to be considered "old" since they were just written. This is the newest version which was updated two days ago.
It is only correct to say that the 4-force (i.e. non-inertial forces) on a particle in free-fall in a gravitational fied zero. However according to Einstein's Equivalence Principle the gravitational force is an inertial force. However inertial forces are not 4-vectors. They are related to the "affine connection" which is not a 4-vector. This is a well known fact in general relativity.
It's not as if I'm alone in this position. In fact this is how I learned it. Actually to be precise - this is how I learned it when I went beyond the layman's view that is always given that there is no such thing as a gravitational force. That is a view held by people who are stuck in the Newtonian viewpoint. The more I looked into it the more I realized how inaccurate that was since Einstein never held that view. Einstein held that since the gravitation force is similar in nature to the Coriolis force, which is an inertial force, then since the gravitational force is "real" then so too is the Coriolis force. People who say Einstein held/proved that "there is no gravitational force" or claim that the gravitational force is "fictitious" have it all backwards. These people claim that since the Coriolis force is not "real" then the gravitational force, being of the same nature, must also not be a "real" force. These people are being Newtonian and are refusing to view things as Einsteinian. They think that they are being Einsteinian but they are not. So be it.
However some of the best, most authoritative, GR texts out there agree with Einstein - as they should! In fact read what Kip Thorne and Roger Blandford say in their new text
http://www.pma.caltech.edu/Courses/ph136/yr2002/chap11/0211.1.pdf
This derivation of the wave equation is an elementary illustration of the Principle of Equivalence|the equivalence of gravitational and inertial forces, or gravitational and inertial accelerations|which we shall discuss in Part VI as an underpinning for general relativity
theory.
In fact Weinberg has an entire section in his text
Gravitation and Cosmology: Principles and Applications of the General Theory of Relativity entitled
Gravitational Forces (page 70). The section which follows that section states, in the first paragraph
Our treatment of freely falling particles has shown that the field that determines the gravitational force is the "affine connection" [tex]\Gamma^{\lambda}_{\mu\nu}[/tex], whereas the proper time interval between two events with a given infinitesimal coordinate separation is determined by the "metric tensor" [tex]g_{\mu\nu}[/tex]. We now show that [tex]g_{\mu\nu}[/tex] is also the gravitational potential; that is, its derivatives determine the field [tex]\Gamma^{\lambda}_{\mu\nu}[/tex].
There is an article on the gravitational force on light called
The gravitational interaction of light: from weak to strong fields, V. Faraoni, R.M. Dumse, Gen.Rel.Grav. 31 (1999) 91-105
http://xxx.lanl.gov/PS_cache/gr-qc/pdf/9811/9811052.pdf
This article uses the technique's of gravitomagnetism.
