Sum of the square roots of the first n natural numbers
The discussion focuses on calculating the sum of the square roots of the first n natural numbers. It concludes that an exact closed-form solution does not exist, but approximations can be made using integral calculus. The integral approximation of \(\frac{2}{3} n^{\frac{3}{2}}\) is highlighted as a superior method compared to a simple integer approximation formula. Participants agree that while approximations are necessary, they provide a reasonable estimate for practical purposes.
  • Understanding of integral calculus
  • Familiarity with square root functions
  • Basic knowledge of approximation methods
  • Ability to compute powers, specifically \(n^{3/2}\)
  • Research integral approximation techniques in calculus
  • Explore numerical methods for estimating square roots
  • Learn about error bounds in numerical approximations
  • Investigate advanced mathematical software for symbolic computation
Mathematicians, students studying calculus, software developers implementing mathematical functions, and anyone interested in numerical methods for approximating mathematical sums.
Amith2006
Is there a way to find the,"Sum of the square roots of the first n natural numbers"?
I don't think you could do it exactly. You could approximate it by the integral of [itex]\sqrt{x}[/itex], and get a bound on the error.
As StatusX says I'm pretty sure there's no way to do in exactly in closed-form. If you don't have a way to calculate square roots at all (ie. you're doing it without a calculator and don't want to go through an approximation method), then a simple integer approximation would be
[tex]\frac{2}{3}\lfloor \sqrt{n} \rfloor^3 - \frac{1}{2}\lfloor \sqrt{n} \rfloor^2 - \frac{1}{6} \lfloor \sqrt{n} \rfloor + \lfloor \sqrt{n} \rfloor(n-\lfloor \sqrt{n} \rfloor^2),[/tex]
but it's not very good. The integral approximation [itex]\frac{2}{3} n^{\frac{3}{2}}[/itex] is much better, but you have to be able to compute [itex]n^{3/2}[/itex]
([itex]2/3 \lfloor n^{3/2}\rfloor[/itex] is also better than the one I gave above though).
  • · Replies 21 ·
