Which Direction Minimizes the Area of a Moving Square Due to Length Contraction?
The discussion revolves around the effects of length contraction on the area of a square as it moves in different directions within an inertial frame. Participants explore how the orientation of the square relative to its direction of motion influences its area due to relativistic effects.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants examine the implications of length contraction along different orientations of a square, questioning how the area changes when the square moves parallel to its sides versus its diagonals. Some participants express confusion about which dimensions are contracted and how this affects the overall area.
There is an ongoing exploration of the relationship between the direction of motion and the resulting area of the square. Some participants suggest that the area remains constant regardless of the direction, while others are clarifying their understanding of the contraction effects. No consensus has been reached, and multiple interpretations are being discussed.
Participants are working under the assumption that the square is initially at rest and that the speed of motion is constant across the scenarios presented. The discussion includes considerations of geometric properties and relativistic effects without definitive conclusions.
Ester
If you have a drawing of a square (labeled ABCD starting at lower left and going clockwise) and it is first at rest in an inertial frame. When this square moves, length contraction changes its shape. In each of the following three situations the speed is the same, and the velocity is in the plane of the square. when is the area of the object the least if the velocity is directed paralled to:
a) side AB
b) diagonal AC or
c) side AD.
In which of these situations is the area of the object the least?
I know that length contraction occurs only along the direction of the motion. Dimensions perpendicular to the motion are not contracted. That is why choice (a) has the larges area and is not the answer.
The answer is (b), but I don't understand why. Please expain.
Well, if it's directed along diagonal AC, length would contract along that axis... which kind of scales down the square... It'll look more like a parallelogram or rhombus or something. (Can't remember much of my geometry)
But since, in the case of motion along diagonal AC, both sides are contracted, since you have something like this:
http://www.brokendream.net/xh4/contraction.JPG
Which, apparently (according to your answer) has less of an area than a square that's contracted to a rectangle..
Yup..
How is it that "the case of motion along diagonal AC, both sides are contracted" ?
Isn't it one side being contracted, the one parallel to motion?
I'm having trouble picturing this.
In this situation, neither side is parallel to the direction of motion, or perpendicular to the direction of motion. One diagonal is parallel to the direction of motion, and that one gets contracted. The other diagonal is perpendicular to the direction of motion, and is not contracted. Draw the new diagonals, and connect the corners to get the new shape of the diagonally-contracted square.
thanks, I get it now.
The areas are the same whether the direction of travel is parallel to a diagonal or parallel to a side. Consider that the Lorentz contraction will give lengths scaled by a factor 0<k<1, now suppose we have begin with a unit square, traveling parallel to a side gives one side shrunk to length k, and the other untouched, so the area is k*1=k. Now if the direction of travel is parallel to a diagonal originally of length [tex]\sqrt{2}[/tex], then the contracted diagonal is of length [tex]k\sqrt{2}[/tex] while the other diagonal is still of length [tex]\sqrt{2}[/tex]. Consider the triangles on either side of the unchanged diagonal: they each have a base of [tex]\sqrt{2}[/tex] and a height of [tex]\frac{k\sqrt{2}}{2}[/tex] and hence they each have an area of (1/2*base*height) = [tex]\frac{1}{2}*\sqrt{2}*\frac{k\sqrt{2}}{2} = \frac{k}{2}[/tex] and since there are two triangles the total area is [tex]2*\frac{k}{2}=k[/tex]. So the areas are the same either way.
I agree with benorin: The direction that the square moves doesn't matter. Whatever the direction, one linear dimension will shrink by the same fraction, thus the change in area will be the same.
The correct answer is not listed.
  • · Replies 26 ·
  • · Replies 45 ·
  • · Replies 60 ·
  • · Replies 83 ·
