How to prove P=(-1)^L, c=(-1)^{L+S} for q \bar q
  • Context: Graduate
  • Thread starter Thread starter BuckeyePhysicist
The discussion revolves around proving the parity and charge conjugation properties for quark-antiquark pairs and tetraquarks. It includes theoretical considerations related to quantum numbers and their implications in particle physics.
  • One participant asks how to prove the relations $P=(-1)^L$ and $C=(-1)^{L+S}$ for quark-antiquark pairs, and inquires about the same for tetraquarks.
  • Another participant requests additional information to clarify the initial query.
  • A participant states that for two particles, the relative parity of a fermion and its antiparticle is negative, leading to $P=(-1)^{L+1}$ for quark-antiquark pairs, citing the example of the spin-zero pion.
  • It is noted that $C=(-1)^{L+S}$ is valid for spin 1/2 fermion-antifermion pairs, with an explanation involving spatial and spin position reversals contributing to the charge conjugation eigenvalue.
  • For tetraquarks, a participant claims that $P=(-1)^{L1+L2+L3}$ due to three internal orbital angular momenta, while charge conjugation depends on how the quarks and antiquarks are coupled.
  • A question is posed regarding the charge conjugation for a specific coupling scheme of tetraquarks, suggesting a formula involving multiple factors of $(-1)$ based on angular momentum quantum numbers.
  • Another participant argues that coupling quark-antiquark pairs first is simpler and critiques the proposed formula for charge conjugation, asserting that it should be $C=(-1)^L$ and emphasizing the need for internal quantum numbers to match for eigenstates of charge conjugation.
Participants express differing views on the correct approach to calculating charge conjugation for tetraquarks, and there is no consensus on the validity of the proposed formulas. The discussion remains unresolved regarding the specific charge conjugation properties in the context of the coupling schemes presented.
Some participants' claims depend on specific assumptions about the coupling of quarks and the definitions of angular momentum quantum numbers, which are not fully detailed in the discussion.
BuckeyePhysicist
How to prove
Code:
$P=(-1)^L$,
$C=(-1)^{L+S}$
for
Code:
$q \bar q$
And $P=?$, $C=?$ for tetraquarks
Code:
$[(q_1 q_2)_{S_1}(\bar q_1 \bar q_2)_{S_2}$
Err, a bit more info please...
marlon
BuckeyePhysicist said:
How to prove
Code:
$P=(-1)^L$,
$C=(-1)^{L+S}$
for
Code:
$q \bar q$
P=(-1)^L for two particles. The relative parity of a fermion and its antiparticle is negative. So P=(-1)^(L+1) for q-qbar.
e.g., the spin zero pion has negative parity.
C=(-1)^(L+S) is correct for spin 1/2 fermion-antifermion.
e.g., the pi0 has C=+1.
To get the C eigenvalue, you have to reverse the spatial positions (-1)^L,
and the spin positions, which gives (-1)^(S+1) in adding 1/2+1/2=S.
There is another factor of (-1) when two fermiions are exchanged.
For tetraquarks, P=(-1)^(L1+L2+L3), because there are three internal orbital angular momenta. C depends on how you couple the quarks and antiquarks. Of course, C only applies to a neutral particle.
C is simpler when you first couple q to qbar. Then C for each pair is as above.
What if I couple q_1 q_2 first with total angular momentum quantum number: J_1, and couple \bar q_1 and \bar q_2 together with J_2. And at last couple the diquark with the anti-diquark[or di-antiquark] with orbital momentum L. What I get for C for this tetraquark?
Is it (-1)^2 * (-1)^{J_1+1}* (-1)^{J_2+1} * (-1)^{L} ?
Coupling q-qbar first is simpler and more reasonable (since the q-qbar attraction is greater).
Your formula for C is wrong.
For your coupling C=(-1)^L, and you need the internal J,L,S to be the same for each diquark to have an eigenstate of C.
