| Thread Closed |
Coplanar vectors |
Share Thread | Thread Tools |
| Aug8-06, 10:55 PM | #1 |
Coplanar vectors
The numbers in brackets are supposed to be in subscript so V(2) would be V subscript 2 and the number in front is just multiply, all the variables are vectors so they have a arrow on top.
Determine if, W(1) = 2V(1) + 3V(2) , W(2) = V(2) + 2V(3) and W(3) = -V(1) - 3V(3) are coplanar i dont understand how to do this. i tried to use the property that if they are coplanar therefore they also must be colinear therefore [Note: C is the only variable that is not a vector it is a unknown integer.] C(1)W(1) + C(2)W(2)....etc = 0 but i cant think of how that would resolve am i on the right track? |
| Aug9-06, 06:19 AM | #2 |
Recognitions:
What you probably meant was linearly dependent. To show that they are linearly dependent, you have to show that your equation has a solution for the C's where the C's are not all 0. Just substitute in the definition of the W's and solve. I assume that the question asks whether the W's are coplanar for ALL choice of the V's, so you need to determine whether there is some choice of C's such that each of the V's in the equation cancels to 0. |
| Aug9-06, 04:44 PM | #3 |
But i cant solve it there are too many variables.
i subbed in the values for W vectors and then i expanded it so now i have like C(1)V(1)+C(1)V(2) etc.. then i added up all the V(1) vectors and ended with sumthing like V(1)[C(1)+C(2)]=0 then that led me to [C(1)+C(2)]=0 cause C would be the number of V and for it to be zero they would have to cancel out. i did the same for all of the V's now i have a set of these i cant solve it.... there are to many variables |
| Aug9-06, 05:18 PM | #4 |
Recognitions:
Coplanar vectors
From what you've described there aren't too many variables. Assume that the V's are nonzero (i.e. sufficiently general--the problem is not very well defined as you've stated it, so I'm assuming it means for any V's). Then you have
V(1)[C(1)+C(2)]=0 implies C(1) + C(2) = 0 Though actually the equation you should have for V(1) is V(1)[2C(1) - C(3)] = 0 |
| Aug9-06, 07:19 PM | #5 |
Do you mean you don't know how to do 3 equations in 3 unknowns?
You want to show that W1 = 2V1 + 3V2 , W2 = V2 + 2V3, and W3 = -V1 - 3V3 are coplanar. Three vectors are coplanar if and only if they are dependent- that is if there exist some non-trivial ([tex]\alpha[/tex], [tex]\beta[/tex], [tex]\gamma[/tex] not all equal to 0) such that the linear combination [tex]\alpha W_1+ \beta W_2+ \gamma W_3= 0[/tex] [tex]\alpha(2V_1+ 3V_2)+ \beta(V_2+ 2V_3)+ \gamma(-V_1- 3V_3)= 0[/tex] [tex](2\alpha-\gamma)V_1+ (3\alpha+ \beta)V_2+ (3\beta- 3\gamma)V_3= 0[/tex] My first thought was that we would need to know more about V1, V2, and V3 but I don't think we do. If V1, V2, and V3 are themselves dependent, then they are coplanar and any linear combination of them is coplanar. So the only question is if V1, V2, and V3 are independent vectors. If V1, V2, and V3 are independent then in order to have [tex](2\alpha-\gamma)V_1+ (3\alpha+ \beta)V_2+ (3\beta- 3\gamma)V_3= 0[/tex] we must have [tex]2\alpha- \gamma= 0[/tex] [tex]3\alpha+ \beta= 0[/tex] [tex]3\beta- 3\gamma= 0[/tex] The three vectors W1, W2, and W3 are coplanar if and only if there exist solutions to those equations other than [tex]\alpha= \beta= \gamma= 0[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Coplanar vectors
| Proving 3 vectors are coplanar | Precalculus Mathematics Homework | 26 | ||
| [SOLVED] Coplanar | Calculus & Beyond Homework | 1 | ||
| Coplanar vectors and linear dependance | Calculus & Beyond Homework | 1 | ||
| Coplanar vectors | Introductory Physics Homework | 7 | ||
| 3D | coplanar vectors | General Math | 4 | ||
