How Does Friction Affect the Acceleration of Stacked Blocks?
The discussion focuses on calculating the acceleration of an upper block (M1) with a mass of 16.5 kg sliding on a lower block (M2) with a mass of 26.5 kg, under the influence of a horizontal force of 94 N. The kinetic friction coefficients are 0.405 between the blocks and 0.105 between the lower block and the flat surface. The calculated acceleration of the upper block M1 is 1.41 m/s², derived from applying Newton's second law and solving the equations for both blocks simultaneously.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams (FBD)
  • Familiarity with kinetic friction coefficients
  • Basic algebra for solving simultaneous equations
  • Study the application of Newton's second law in multi-body systems
  • Learn how to construct and analyze free body diagrams for complex systems
  • Explore the effects of different friction coefficients on motion
  • Investigate the dynamics of stacked blocks under various forces
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of friction and acceleration in multi-body systems.
HW_unlimited
A block M1 of mass 16.5 kg sits on top of a larger block M2 of mass 26.5 kg which sits on a flat surface. The kinetic friction coefficient between the upper and lower block is 0.405. The kinetic
friction coefficient between the lower block and the flat surface is 0.105. A horizontal force F = 94 N pushes against the upper block, causing it to slide. The friction force between the blocks then causes the lower block to slide also. Find the magnitude of the acceleration of the upper block.
94N -----> [ M1 ]
[ M2 ]
i found the net force acting on m1 but i don't know how to go from there ...im just stuck on this one
It sounds a lot more complicated than it really is.
First draw a FBD of M1. Aside from gravity and its reaction, there are really only 2 forces: the applied force and the friction between M1 and M2. Find the friction force
[tex]f = \mu F_N[/tex]
[tex]f = (0.405)(16.5kg)(9.81\frac{m}{s^2})[/tex]
[tex]f = 65.56N[/tex]
So here's what the FBD would look like:
94N----->[M1]<--------65.56N
The resultant force would be 28.44N which makes the acceleration 1.724 m/s^2
You were probably trying to factor in the mass of M2 as well. Since the question only asks for M1, you only need to look at M1.
The first step in solving this problem is to draw a free body diagram for each block, showing all the forces acting on them. For the upper block M1, there are three forces: the pushing force F, the normal force from the lower block, and the kinetic friction force from the lower block. For the lower block M2, there are also three forces: the normal force from the ground, the kinetic friction force from the upper block, and the weight of the block.
Next, we can apply Newton's second law (F=ma) to each block separately. For the upper block M1, the net force is equal to F-friction, where friction is the kinetic friction force from the lower block. So we have:
F-friction = M1a
For the lower block M2, the net force is equal to friction-weight, where friction is the kinetic friction force from the upper block. So we have:
friction-weight = M2a
Now we can substitute the given values into these equations. The pushing force F is 94 N, and the friction force between the blocks is equal to the coefficient of kinetic friction (0.405) times the normal force between the blocks. We can find the normal force by using Newton's third law: the normal force from the lower block on the upper block is equal in magnitude to the normal force from the upper block on the lower block. So we have:
F-0.405(M1+M2)g = M1a
0.405(M1+M2)g-M2g = M2a
We can solve these two equations simultaneously to find the acceleration of the upper block, a. Plugging in the given values for M1, M2, and g, we get:
94 - 0.405(16.5+26.5)(9.8) = 16.5a
0.405(16.5+26.5)(9.8) - 26.5(9.8) = 26.5a
Solving these equations, we get a = 1.41 m/s^2. This is the acceleration of the upper block as it slides down the lower block and the two blocks slide together on the flat surface.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 18 ·
