How Do Fajan’s Rules Influence the Ionic Nature of a Bond?
The discussion revolves around the factors that determine the ionic nature of a bond, specifically in the context of Fajan's Rules. Participants explore the roles of cation polarizing ability and anion electronegativity, addressing the complexities of bond polarity and covalent character.
  • One participant questions whether the ionic nature of a bond is determined by the polarizing ability of the cation or the electronegativity of the anion.
  • Another participant clarifies the distinction between polar and ionic bonds, noting that ionic bonds can be seen as very strong polar bonds where electrons are effectively transferred.
  • A participant emphasizes that multiple properties influence bond polarity and that electronegativity is defined for atoms, not ions.
  • Fajan's Rules are discussed, with a participant asserting that smaller cations and larger anions lead to more covalent character, while another challenges this interpretation, stating that the opposite is true.
  • There is a discussion about the distribution of charge in ionic compounds and how it relates to the covalent nature of the bond, with specific examples like LiI and KI being used to illustrate points.
  • Clarifications are made regarding the nature of shared pairs of electrons and how they relate to electronegativity, with a participant arguing that shared pairs can only be discussed in the context of covalent molecules formed from neutral atoms.
Participants express differing views on the application of Fajan's Rules and the definitions of ionic versus covalent bonds. There is no consensus on the interpretation of these concepts, and the discussion remains unresolved.
Participants note the complexity of defining electronegativity in the context of ions and the need for familiarity with ionic radii when applying Fajan's Rules. The discussion highlights the nuances in understanding bond polarity and the factors influencing it.
konichiwa2x
What determines the ionic nature of a bond? I am a bit confused regarding this.
Is it the polarising ability of the cation or the greater electronegativity of the anion? Regarding fajan's rules, smaller the size of the cation (and greater the charge) and smaller the size of the anion, greater is the covalent nature of the bond. So in this case, the bonding pair of electrons is pulled closer to the core of the cation, resulting in accumulation of a slight negative charge for the cation? right? But in some other cases, the shared pair(s) of electrons are pulled closer to the anion due to the greater electronegativity of the anion. So.. does this mean that the bonding pair of electrons can be pulled closer to either to the cation or the anion??
Can someone please explain?:confused:
Chemistry news on Phys.org
Are you asking about polar bonds or ionic bonds?
The title says polar, but in the question you keep using terms like "ionic", "cation", and "anion".
In a polar bond, one atom is attracting the electrons more than the other atom. The difference in the atoms' electronegativity can help determine which atom will pull in the electrons more. When the difference in electronegativity is zero, the atoms share the electrons equally. When it is non-zero, the electrons spend a little more time around one atom than they do around the other. The imbalance in sharing electrons creates partial charges on the atoms, but not full blown ions.
An ionic bond is just a very strong polar bond, so strong that, for all intensive purposes, the electron from one atom has been completely removed and is not around another atom. Removing the electron from the original atom gives it a positive charge, making it a cation. The addition of an electron to the second atom gives it a negative charge which makes it an anion.
And likely for good reason - this is one of those questions you can stump most high school chemistry teachers with - it is very poorly understood and taught.
First, there is more than one property that determines the polarity of a bond. Second, the properties of both the species involved in the bond are important. And third, 'electronegativity' is not defined on an ion, it is defined for an atom (typically).
What are these properties and how do they affect the polarity of the bond? There are two approaches to answering that. The more popular approach is through Fajan's Rules (as opposed to Pauling's approach). The difference between these approaches is the Fajan treats the polar covalent bond as a perturbation (or small deviation) from the purely ionic bond, while Pauling treats it as a perturbation from a perfectly non-polar covalent bond.
In Fajan's approach, you start with a (hypothetical) "purely ionic compound" and then redistribute charge according to certain rules to make the final compound more covalent than your starting condition. This starting point requires that you are apply the rules to ions (rather than neutral atoms), so you must be familiar with the (periodic trends in) ionic radii before you can use Fajan's Rules successfully.
No, this is not right. Go over Fajan's Rules again. It takes a smaller cation and/or a larger anion to make a more covalent bond (effective charge being constant). NaI is much more covalent (or much less polar) than NaCl (since I- is bigger than Cl-).
No, there is never a net negative charge on the cation. And since you start from the case of a perfectly ionic molecules, there is no such thing as a bonding pair.
If you compare LiI with KI, because of the smaller size of the Li+ ion than the K+, the former is better able to "suck" some partial negative charge out of the anion, I- (according to Fajan's Rule#1). As a result, the positive charge (+1) on the Li+ ion is reduced more than the positive charge on the K+ ion would be. Also, Li+, by sucking out more negative charge from I-, makes the anion not-so-negatively charged anymore. As the result, the net partial charges on Li([itex]\delta +[/itex]) and I([itex]\delta -[/itex]) in LiI are smaller than the net partial charges on K(bigger [itex]\delta +[/itex]) and I(bigger [itex]\delta -[/itex]) in KI. In other words, LiI is more covalent (or non-polar), and KI is more ionic (or polar).
Any shared pair is always pulled closer to the more electronegative species, typically the non-metal that forms the anion. But you can talk of shared pairs and electronegativities only if your starting point is a covalent molecule formed from neutral atoms (ie: if you are using the Pauling formalism), not an ionic molecule formed between ions. There is nothing to share in an ionic molecule - the two ionic species have their octets and are happy.
Note that the Fajan formalism does not create a net negative charge on the cation, it only reduces the amount of positive charge. You always end up with a net negative charge on the ion formed from the more electronegative species (the anion) and a net positive charge on the cation.
No - as explained above.
ok thanks a lot! I think it finally makes sense.:approve:
27K
