Sedna must be a planet (at least for now) according to new definition?
  • Context: Undergrad
  • Thread starter Thread starter ACG
    Definition Planet
The discussion centers around the classification of Sedna as a planet based on a new definition of what constitutes a planet. Participants explore the implications of Sedna's unique orbital characteristics and the vagueness of the current definition, while also referencing other celestial bodies like Pluto and Ceres.
  • Some participants argue that Sedna fits the definition of a planet because it is in a region of space that appears to have no other known bodies, similar to Pluto's situation in 1930.
  • Others contend that the definition of a planet is too vague and could lead to different classifications if applied by an external observer.
  • One participant questions whether the area around Sedna is truly cleared out and suggests that Sedna may have been perturbed into its current orbit rather than having cleared its vicinity.
  • Another participant raises concerns about Sedna's highly eccentric orbit, arguing that the concept of "clearing out" its neighborhood becomes problematic in this context.
  • Some participants draw parallels with Pluto, noting that it crosses Neptune's path and questioning its classification as a planet based on the same criteria.
  • A later reply disputes the claim that Pluto's orbit crosses Neptune's, providing clarification on their orbital relationship.
Participants express multiple competing views regarding the classification of Sedna and the adequacy of the current definition of a planet. The discussion remains unresolved, with no consensus reached on whether Sedna should be classified as a planet.
The discussion highlights limitations in the current definition of a planet, particularly regarding the assumptions about orbital clearing and the implications of eccentric orbits. There are unresolved questions about the nature of the region surrounding Sedna and the criteria for classification.
ACG
Hi!
I saw the definition of a planet -- basically anything differentiated that has cleared everything in the area and orbits the central star.
Pluto doesn't count because it's in the middle of a belt.
Ceres doesn't count because it's in the middle of a belt.
Sedna -- well, Sedna's an interesting case. You see, its aphelion is INSIDE the Oort Cloud and its perihelion is OUTSIDE the Kuiper Belt.
Even astronomers aren't sure how it got there. This probably means there isn't much out there.
So we have a large object in a zone which appears (at least for the time being) to have nothing in it.
This makes Sedna a planet -- at least temporarily. It's basically in the same position Pluto was in 1930 -- it's in an area where there are no other known bodies. Perhaps we'll find some more Sednas in the future, in which case Sedna can be downgraded. But for now -- it sure fits the definition! The definition says nothing about how eccentric the orbit is.
What's wrong with this reasoning?
ACG
Astronomy news on Phys.org
I don't see any problem with the reasoning, which is the big problem with this definition...it is WAY too vague to be useful. If you were to give an alien these rules, plop them in our solar system, and have them tell us what should be classified as a planet and what should not, I'd bet you we'd have an answer very different from 8!
Were going to need a subforum about the defiention of a planet now...
We don't really know if that area of space is cleared out. In fact, many astronomers view Sedna as the "frist" Oort Cloud object to be spotted. And even if the area is clear, Do we really believe that Sedna cleared it? I think it more likely that that this body was perterbed and "fell into" this empty region (if it is empty).
You also have to consider the following: Sedna's orbit is highly eccentric, so the rule about it clearing out all of the mass in its vicinity doesn't make sense. If an object is in a circular orbit, it's fairly obvious what its neighborhood is. But if it's eccentric, the idea of a neighborhood makes new sense. Yes, its orbit is well defined. But given astronomical time, the orbit will precess like the hour hand on a clock and influence entirely different areas of the Solar System. Rotate Jupiter's orbit by 90 degrees and you still get the same orbit, more or less. Rotate Sedna's by 90 degrees and the new orbit is completely different.
For something this eccentric to truly "clear everything out", it would have to knock out EVERYTHING at ANY distance between perihelion and aphelion, which makes no sense.
Also Pluto crosses Neptune's path. Neptune, thus, has not cleared all the debris out of its orbital path and should not be considered a planet either. I think there are lots of Earth orbit crossing asteroids as well, no?
For the fifth time or so: No it doesn't!
Pluto's orbit is tilted compared to the ecliptican, and its orbit never crosses Neptune's. In fact the orbits are several AU appart at their closest points.
This makes Sedna...
Sedna is a planette.
11K
  • · Replies 28 ·
20K
9K
