Altering Data Rate of AVI Video for Lag-Free Playback
  • Thread starter Thread starter Petey B
    Data Rate Video
The discussion revolves around the issue of altering the data rate of AVI videos to address playback lag on a TV. Participants explore potential causes of lag, including data rate, video quality, and playback methods, while considering various technical aspects of video encoding and transmission.
  • One participant inquires about methods to alter the data rate of AVI videos due to playback lag experienced on a TV.
  • Another participant suggests using video editing software for re-encoding but doubts that data rate is the cause of lag, citing the low data rate of 93 kbps as inadequate for video quality.
  • A different participant questions the source of the 93 kbps video, noting that typical data rates for videos of similar resolution are significantly higher, ranging from 2000 kbps to over 30000 kbps for high-definition formats.
  • One participant asserts that video lag is unrelated to data rate, attributing it instead to CPU performance, codec issues, or frame rate problems.
  • The original poster describes using a wireless media connector to play videos from a computer, noting that some videos lag on the TV but play fine on the computer.
  • Another participant proposes that lag could be due to high data rates in certain scenes exceeding the capacity of the wireless connection and discusses the impact of deinterlacing on playback quality.
  • It is mentioned that most codecs use variable bit rates, meaning that the data rate fluctuates based on scene complexity, complicating the assessment of a video's overall data rate.
Participants express differing views on the relationship between data rate and video lag, with some attributing lag to data rate issues while others argue it is more likely related to playback hardware or codec problems. No consensus is reached on the primary cause of the lag.
Participants highlight the variability of data rates in video encoding and the potential influence of playback methods on perceived lag, but do not resolve the specific factors contributing to the original poster's issue.
Petey B
Hey,
Is there a way to alter the data rate of a avi video.
The problem is when i watch a video on my tv it has a slight lag to it, some videos do and some dont. i compared all the info of the videos and the ones that laged had a video data rate of 93kb/s.
thanks
Computer science news on Phys.org
You can use video editing software like Adobe Premiere to re-encode ("transcode") a video file from one data rate to another.
However, I don't think your "lag" problem has anything to do the data rate of the video -- it is probably just a poorly-made video in the first place. 93 kbps is actually an incredibly low data rate for video.
Note that increasing the data rate of a poor movie isn't going to make it any better -- that would require the creation of new information, which the computer cannot magically do.
- Waren
Where did you find a video source that had a 93kbps rate? As mentioned its very low. For 640x480 videos I use about 2000kbs just for the video, which may bit of overkill, but file sizes are reasonable for 1 to 10 minute videos. DVD's range about 3000kbs to 9800kbs. HDTV (1080i) is 19.25mbps. BluRay DVD's (1080p) are even faster, 36mbps (1x) and 72mbps (2x), they need 54mpbs (1.5x) to get full quality transfer.
Video lag has absolutely nothing to do with data rate.
Video "lag" usually happens when either your CPU cannot decode the video fast enough, you have installed incorrect codecs or splitters, or there is a problem with the video's frame rate.
How are you playing your videos on TV? Is it directly connected to your computer? If so, are you saying that this lag does not exist on your computer screen?
Well i have a D-link media connecter thing (some bull**** name) where it will play movies from my computer wirelessly.
ive downloaded a bunch of movies and most of them run great, but some have a little lag, when i watch them on my computer they are fine but not on my tv.
if u want any screen shots of n e thing that will help let me know.
Thanks!
In that case, the lag can be caused by the data rate. It could be that the data rate at some scenes are too high for the wireless connection.
I'd like to bring up two points for your own information however:
- It is very common for video to look okay on TV and "laggy" on the computer, due to a bad deinterlacing scheme. The computer uses a progressive display while TVs are interlaced. DVDs come interlaced.
- MOST codecs encode using variable bit rate. This includes MPEG-2 (default DVD codec) and MPEG-4 (default Blu-ray/HD-DVD codec). This means that the data rate is not constant. You cannot simply say this video is 93kbit/s. The bit rate changes depending on how much action there is in that particular scene.
10K
  • · Replies 36 ·
  • · Replies 58 ·
