Spivak's Calculus: The Basic Properties of Numbers
The discussion revolves around properties of numbers as explored in Spivak's Calculus, specifically focusing on inequalities involving powers and roots. Participants are addressing various proofs related to the behavior of numbers under exponentiation, particularly in the context of odd and even powers.
  • Mixed
  • Participants explore induction as a method for proving inequalities involving powers, questioning whether it can be applied in certain cases. Others suggest alternative approaches, including case analysis based on the signs of the numbers involved.
Several participants have provided insights and partial proofs, particularly regarding the properties of powers for both odd and even integers. There is an ongoing exploration of different cases and conditions, with some participants expressing confusion or seeking clarification on specific steps in their reasoning.
Participants are working under the constraints of not using induction in certain contexts and are attempting to prove statements that involve both positive and negative numbers. The discussion includes the need to clarify assumptions about the values of x and y in various scenarios.
Tasaio
Hi there,
I'm using Spivak's Calculus. Some of these questions are giving me trouble...
6.(a)
Prove that if 0 <= x < y, then x^n < y^n, n = 1, 2, 3, ...
Suppose 0 <= x < y.
Since this is Chapter 1, I shouldn't be using induction. ;-)
I'll try anyway.
Let S be the set of positive integers n for which:
If 0 <= x < y then x^n < y^n
Case: n = 1
Since x < y, then x^(1) = x < y = y^(1)
So 1 in S.
Assume k in S.
Then if 0 <= x < y, then x^k < y^k.
Case: n = k + 1.
Suppose 0 <= x < y.
Here, I get stuck.
Does anyone have an idea about what to do next? Also, is there possibly a way to do with question without using induction?
Thanks in advance for any assistance,
Tasaio
well that's a good approach. It would go like this.
Let P(k) be the statement: 0<=x^k<y^k
P(1): 0<=x<y is given
Assume P(n)... ie: 0<=x^n < y^n
Show P(n+1) is true based on P(n)
ie: show 0<=x^(n+1) < y^(n+1) assuming P(n) is true.
Thats a quick way to do it with induction.
Thanks for the reply!
As you wrote, I need to show that P(k) --> P(k + 1).
Assume P(k).
Then x < y --> x^k < y^k.
Now show: P(k + 1).
Suppose x < y.
. <-- Proof that x^(k + 1) < y^(k + 1)
Any tips on how I can prove this?
look at it this way.
since x^k<y^k and x<y
x^k*x < x^k*y<y^k*y
which is equivalent to
x^(k+1)<y^(k+1)
Wow -- I can't believe I missed that. :smile:
Here's one I'm trying to figure out, that's much more difficult.
Prove:
If 0 < a < b,
Then
a < sqrt(ab) < (a + b) / 2 < b
My solution
It's easy to show:
a = sqrt(a*a), since a > 0
sqrt(a*a) < sqrt(a*b) since a < b
So a < sqrt(ab)
b = 2b/2 = (b + b) / 2 > (a + b) / 2, since a < b
So (a + b) /2 < b
Now we come to the crux of the problem:
Prove
Work backwards -- multiply both sides by 2
2*sqrt(ab) < a + b
Square both sides
4(ab) < (a + b)^2
4ab < a^2 + 2ab + b^2
2ab < a^2 + b^2
ab < (a^2 + b^2) / 2
Clearly the expression on the right is the "average" of the squares of a and b.
I've tried and tried, but can't figure out the next step. Any hints you can give me?
Thanks!
since a,b etc are all positive, you let x^2=a, y^2=b, for positive x and y. Then what are you asked to prove about x and y?
Let x^2 = a
Let y^2 = b
We were asked to show:
Subbing in x and y:
sqrt(x^2 * y^2) < (x^2 + y^2) / 2
sqrt((xy)^2) < (x^2 + y^2) / 2
xy < (x^2 + y^2) / 2
2xy < (x^2 + y^2)
This is just like the result I obtained using a and b. How can I use this?
you mean you don't recognize x^2-2xy+y^2? (prepare for another of those 'how didn't I see that' moments.)
ARGH! You're right, how didn't I see that?! :smile: :smile: :smile: :rolleyes: :confused: :mad: :confused: :confused: :devil: :devil: :devil: :devil: :devil:
2ab < a^2 + b^2
0 < a^2 - 2ab + b^2
0 < (a - b) ^2
0 < (a - b)(a - b)
This is true iff a != b
Since a < b, it is true.
Thus we just need to work backwards from here.
Proof
Since a < b
Then 0 < b - a
So
0 < (b - a)^2
0 < (a - b)^2
0 < a^2 - 2ab + b^2
2ab < a^2 + b^2
4ab < (a + b)^2
2sqrt(ab) < a + b
QED
Thanks so much for your help with that question -- it had be going for at least an hour!:rolleyes:
This next one seems trickier:
Prove that if x < y and n is odd, then x^n < y^n.
My solution
Suppose x < y.
Suppose n is odd.
We want: x^n < y^n
0 < y^n - x^n
0 < (y - x)(y^n-1 + y^n-2*x + ... + yx^n-2 + x^n-1)
Since n is odd, then
n = 2k + 1, where k is an integer.
But n >= 1, so k >= 0
Let's try induction, again:
Proof by Induction
Let S be the set of positive integers k for which:
x < y and k >= 0 --> x^(2k + 1) < y^(2k + 1)
Suppose x < y.
Case: k = 0
Then 2k + 1 = 2(0) + 1 = 1
So x^(2k + 1) = x^1 = x < y = y^1 = y^(2k + 1)
So 1 in S.
Asssume t in S.
Then x^(2t + 1) < y^(2t + 1)
Case: k = t + 1
Then
x^(2t + 1) = x^(2t) * x < y^(2t) * x < y^(2t) * y = y^(2t + 1)
Thus x^(2t + 1) < y^(2t + 1)
So t in S --> (t + 1) in S.
Thus S = N.
QED
Does that look right?
Why not just use the first result in the thread? If n is odd x^n is the same as |x|^n (|x| means the abs value of x, i.e. forget the sign.)
The first result I can think of was:
0 <= x < y --> x^n < y^n, n= 1, 2, 3, ...
I can't use this, since the hypothesis has the additional requirement that 0<=x.
I'm trying to prove x < y --> x^n < y^n for n odd. (There is no requirement that 0<= x)
Are you sure that x^n = |x|^n for n odd?
What about x = -1, n = 3?
Then
(-1)^3 = -1 < 1 = |-1|^3
They are not equal.:frown:
6(c)
Prove that if x^n = y^n and n is odd, then x = y.
Suppose x^n = y^n.
Suppose n is odd.
Then there exists k in Z, such that n = 2k+ 1.
But n >= 1, so k >= 0.
We have x^(2k + 1) = y^(2k + 1)
We need to prove x = y for all k >= 0. Let's use Proof By Induction.
Proof by Induction
Case: k = 0
Suppose x^(2k + 1) = y^(2k + 1).
Then x^(2(0) + 1) = y^(2(0) + 1)
x^(1) = y^(1)
x = y
Thus 1 in S.
Assume t in S.
Then x^(2t + 1) = y^(2t + 1) --> x = y
Case: k = t + 1
Suppose x^(2(t + 1) + 1) = y^(2(t + 1) + 1)
Then
x^(2t + 2 + 1) = y^(2t + 2 + 1)
x^(2t + 1 + 2) = y^(2t + 1 + 2)
x^2(x^(2t + 1)) = y^2(y^(2t + 1))
Where should I go from here? Any advice?
Try breaking into the following 3 cases
1) [tex]0 \leq x < y[/tex], this one should be obvious from the first result of the thread
2) [tex]x < 0 \leq y[/tex]
3) [tex]x < y \leq 0[/tex], hint: consider (-x) and (-y) and the first result of the thread.
Try a proof by contradiction. First assume x<y and use the above result. Then do the same assuming y<x.
Then
Of course that is wrong: there is a minus sign missing.
THe point is you dont' need to do anything else other than look at some cases and invoke the first result you proved. If 0<=x<y then the first argument applies, if x<0<=y then there is nothing to prove (x^n is all ways negative for odd n), and if x<y<0 then you can again use the first argument since 0<-y<-x.
Just because something isn't exactly in the form you're used to doesn't mean you can't put it in the form you're used to.
I solved the other 2 cases, but number 2 is giving me trouble.
Case: [tex]x < 0 \leq y[/tex]
Then
[tex]x - y < -y \leq 0[/tex]
Since x < 0 and [tex]-y \leq 0[/tex]
Then [tex]x + (-y) \leq x[/tex]
So
[tex]x-y \leq x[/tex]
The proof of case 2 was given in my post: a negative n umber to an odd power is a negative number.
Yes, I solved it by breaking it into 2 cases: y > 0 and y = 0. :cool:
6. (d)
Prove that if x^n = y^n and n is even, then x = y or x = -y
My attempt
Suppose x^n = y^n and n is even.
Then x^n = y^n.
And n is even.
I'll try Proof by Contradiction.
Proof by Contradiction: Suppose !(x = y or x = -y)
Then (x !=y and x != -y) by DeMorgan's Theorem
I'm stuck. Where do I go from here?
Can't you just take the nth root of both sides and get +/- x = +/- y?
That would be nice, the problem is that one (referring to anyone working through the text) has not yet proven that nth roots exist.
What this problem shows is that for even n, if nth roots exist for a positive number then they have the same absolute value. Likewise, the previous problem showed that for odd n, if nth roots exist for some number (positive or negative) then they are unique.
Tasaio: The proof is similar to the previous problems. Try breaking the problem into cases and make use of work you have already done, also note that (x)^n = (-x)^n for even n.
Hi,
Here's my attempt so far...
Prove: x^n = y^n and n even --> x = y OR x = -y
My attempt
Suppose x^n = y^n and n even for n = 1, 2, 3,...
Proof by Contradiction: Suppose NOT(x = y OR x = -y)
Then x != y and x != -y (by DeMorgan Theorem)
Cases:
0 < x < y
0 = x < y
x < 0 = y
x < 0 < y
x < y < 0
Which reduces to:
0 <= x < y (1)
x < 0 <= y (2)
x < y <= 0 (3)
And:
0 < y < x
y = 0 < x
y < 0 = x
y < 0 < x
y < x < 0
Which reduces to:
0 <= y < x (4)
y < 0 <= x (5)
y < x <= 0 (6)
Case (1): 0 < x < y
By 6(a), x^n < y^n for n = 1, 2, 3,...
But x^n = y^n : CONTRADICTION!
Case(2): x < 0 <= y
Case: y = 0
Then x < 0 = y
Then - x > 0 = -y = y
So -x > y >= 0
By 6(a), (-x)^n > y^n for n = 1, 2, 3,...
(-1)^n*x^n > y^n for n = 1, 2, 3...
But since n even,
Then (-1)^n = 1
so x^n > y^n
But x^n = y^n: CONTRADICTION!
Case: y > 0
Then x < 0 < y
-x > 0 > -y
Now x^n = (-x)^n since n even
(-x)^n > 0 since (-x) > 0
