Finding Cable Tension Components with Given Angles
The discussion revolves around determining the tension components in a cable supporting a tree, specifically focusing on the angles and forces involved. The original poster mentions the tension in cable AB and provides two angles related to its orientation, seeking to find the force components and their respective angles with the coordinate axes.
  • Participants explore the relationships between the angles and the force components, questioning the definitions of the coordinate axes and the plane of the ground. There are attempts to clarify the setup and the required calculations for the components of the force.
Some participants have provided guidance on calculating the components of the force based on the angles given, while others have raised questions about the setup and the definitions of the axes. There is an ongoing exploration of the relationships between the angles and the force components, with no explicit consensus reached.
Participants are working with limited information, primarily the tension magnitude and two angles. There is a focus on ensuring clarity regarding the coordinate system and the orientation of the cable relative to the ground and axes.
formulajoe
ive been wrestling with this for an hour and a half, and all I've got it Theta y and Fy.
a tree is being supported by cables. the tension in cable AB is 4.2 KN.
all it gives me to go on is 2 angles. it 40 deg toward z axis from x axis. and the cable makes an angle of 40 deg with the ground. i found Fy to be -2.7 KN and theta y to be 130 deg.
i can even get close to Fx or Fz. if i can get those, finding their respective theta's will be a snap.
Can you provide a picture?
heres a very rough drawing i made with paint. the one 40 deg angle is made with the ground.
Write the components in vector form if you now the resultant and the angle
1) Where are the other cables?
2) What are you trying to find?
I'm just trying to find the component forces of AB, and the corresponding theta's. all that's given is those two angles, and the magnitude of the force.
Please define your x, y, z directions. What is the plane of the ground? What is the vertical direction?
does this help?
heres the exact question.
knowing the tension in cable AB is 5.2 KN, determine (a) the components of the force exerted by this cable on the tree. (b) the angles theta x, theta y, and theta z that the force forms with axes at A which are parallel to the coordinate axis.
Finally I see what you are doing. :smile:
You need the components of the force that the cable exerts on the tree. That force (F) makes an angle of 50 with the y-axis, so:
Fy= - F cos(50)
Fx-z= F sin(50) (magnitude only)
Then:
Fx= F sin(50)cos(40)
Fz= F sin(50)sin(40)
Make sense?
Edit: Corrected the angle from 60 to 50 degrees. (D'oh!)
those answers arent coming out right.
Fy = F X cos 130.
theta y makes an angle of 130 deg. i found this knowing that it made an angle of 40 deg with the ground, so it had to make a 50 deg angle with the tree. 180 - 50 = 130. this answer checks out.
but the other two dont. I've even tried working backwards from the answer, but I am not getting remotely close.
but when the numbers from the answers you gave me are squared, added, and then the square root is taken they equal out to 4.2. are the answers in the book wrong?
Oops! Where I have 60 degrees, I should have 50. Sorry. Now try it..
ahhh, that works perfect now. i don't completely understand how you did it though. i understand the y one completely.
so for the x, you complement the 40 deg angle and take the sin correct? and for the 40 deg angle the stake makes with the x axis, just take the cos right. just kinda treat the x and z axes as the x and y axes? same rules work?
Right, it's easy. Look at my original answer.
You know how to find the y-component. The projection onto the x-z axis is the component perpendicular to y. (If one is cosine, then the other is sine.) Then you just find components (of that projection) in the x-z plane (just like you would with x & y).
  • · Replies 31 ·
