Parametric Equation for Surface Area of Revolution
The surface area (SA) of a solid of revolution around the x-axis can be expressed in parametric terms as SA = 2π∫[a to b] y(t)√([x'(t)]² + [y'(t)]²) dt. For rotation about the y-axis, the formula is SA = 2π∫[a to b] x(t)√([x'(t)]² + [y'(t)]²) dt. The limits of integration, t1 and t2, are determined by the specific parametric equations x(t) and y(t) used. This formulation allows for the calculation of surface areas for curves defined parametrically over a closed interval.
  • Understanding of parametric equations
  • Knowledge of calculus, specifically integration
  • Familiarity with derivatives, denoted as x'(t) and y'(t)
  • Basic concepts of surface area in geometry
  • Study the derivation of the surface area formula for solids of revolution
  • Learn about parametric equations and their applications in calculus
  • Explore integration techniques for complex functions
  • Investigate applications of surface area calculations in engineering and physics
Mathematicians, engineering students, and anyone involved in calculus or geometric modeling who needs to calculate surface areas of solids of revolution defined by parametric equations.
tandoorichicken
I know that the equation for the surface area of any solid of revolution around, say, the x-axis is
[tex]SA = 2\pi\int_{a}^{b} y\sqrt{1 + (\frac{\,dy}{\,dx})^2} \,dx[/tex]
What I need is the same formula except in parametric terms, like if the problem was given in terms of x(t) and y(t). Any takers?
If it revolves about the x-axis on the closed interval [a,b], then
[tex]SA = 2\pi\int_{a}^{b} y(t)\sqrt{[x'(t)]^2 + [y'(t)]^2} \,dt[/tex]
For example. if the surface are of the solid generated by revolving the region enclosed by the curve with parametric equations x(t), y(t) from t = 0 to t = pi/2, then the upper limit, b = pi/2, lower limit a = 0.
If it revolves about the y-axis on the closed interval [a,b], then
[tex]SA = 2\pi\int_{a}^{b} x(t)\sqrt{[x'(t)]^2 + [y'(t)]^2} \,dt[/tex]
The parametric equation for surface area of revolution can be written as:
SA = 2\pi\int_{t_1}^{t_2} y(t)\sqrt{\left(\frac{\,dx}{\,dt}\right)^2 + \left(\frac{\,dy}{\,dt}\right)^2}\,dt
This equation takes into account the changing values of x and y as t varies, and calculates the surface area by integrating over the specified range of t. It is important to note that the limits of integration, t1 and t2, will depend on the parametric equations used to describe the curve being rotated.
