Thread Closed
Need Help with Differential Equation (integrating factor)
Share Thread
Sep5-06, 12:48 PM   #1
Recognitions:
Hi there, I am having a bit of difficulty finding the integration factor for the following problem. The problem lies in taking the integral of a function of two variables. Anyways, heres what I have:
[latex] y^2+y-xy'=0[/latex]
I then divided by x (i prefer it this way), so
[latex] \frac{y^2+y}{x} + y' = 0 [/latex]
then, letting u be a integration factor:
[latex] \frac{duM}{dy} = \frac{duN}{dx}
\\\\\Rightarrow
\frac{du(y^2+y)x^{-1}}{dy} = -\frac{du}{dx}
[/latex]
[latex]
(\frac{du}{dy})(\frac{y^2+y}{x}) + u\frac{2y+1}{x} = -\frac{du}{dx}
[/latex]
Assuming that u is a function of only x, we get rid of the u partial with y term, so:
[latex]
\frac{du}{dx} = -u\frac{2y+1}{x}
\\\mbox{now doing some dividing on both sides and integrating}
\int\frac{\delta\mu}{\mu} = -\int\frac{2y+1}{x}dx
[/latex]
Now this is where I'm stuck. I guess I can't remember how to integrate that right side. Can I just pull the (2y+1) term out of the integral assuming that its contant? Thanks for the help
edit: wow, this latex is really messed up. I'm working on it. The last equation, the integral is correct, and that's the most important part though.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Sep5-06, 09:59 PM   #2
Why not just make the case separable? Seems to me a lot easier this way
[tex] y^2+y - x y^{\prime} = 0 \Rightarrow \frac{y^{\prime}}{y^2+y}=\frac{1}{x} \Rightarrow \frac{dy}{y^2+y} = \frac{dx}{x} [/tex]
and this is an easy integral to do.
Sep6-06, 04:55 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
You can't integrate that last integral precisely because in has y in it. Your assumption that the integrating factor u could be a function of x only is incorrect.
As xman pointed out, this is obviously a separable equation. (Which is the same as saying that
[tex]\frac{1}{x(y^2+ y)}[/tex]
is an integrating factor.)
Sep6-06, 09:50 AM   #4
Recognitions:
wow, I cannot believe that I missed that. It was in the integrating factor section, so I just assumed it to be of that form.
I feel like an idiot, thanks a lot.
Sep6-06, 09:55 AM   #5
Recognitions:
Homework Helper Homework Help
Note that usually, non-linear diff.eqs rarely can be solved by methods of finding integrating factors.
That is, the method of finding an integrating factor is mainly of use for solving linear diff. eqs.
On special occasions, though, you may succeed..
Thread Closed
Similar discussions for: Need Help with Differential Equation (integrating factor)
Thread Forum Replies
Easier way of finding Integrating Factor for Exact Differential Equation?? Calculus & Beyond Homework 4
Integrating Factor Calculus & Beyond Homework 2
Integrating factor Calculus & Beyond Homework 3
integrating factor Introductory Physics Homework 2
How do we find Integrating factor for a General Diff equation Differential Equations 6
