Oxford Admission Test: Answers to 2 Problems
  • Thread starter Thread starter mohlam12
    Admission Test
The discussion revolves around two problems from a sample Oxford admission test. The first problem involves calculating the speed at which an image approaches a person running towards a plane mirror. The second problem concerns determining the amount of hot water needed to achieve a specific temperature in a bath containing water at a lower temperature.
  • Participants explore the concept of relative motion in the first problem, questioning how the speed of the image is perceived. In the second problem, there is discussion about applying conservation of energy principles and the relevant equations.
The discussion is active, with participants offering different perspectives on the first problem's interpretation and the second problem's approach. Some participants express uncertainty and seek clarification, while others provide insights into the reasoning behind their answers.
Participants are navigating through assumptions related to the physics of mirrors and heat transfer, with some expressing confusion about the application of concepts in the problems.
mohlam12
hello everyone, i saw this two problems on a sample oxford admission test and i was wondering what the answer is ...
1)
If you run at 5 m/s towards a plane mirror, at what speed does your
image approach you?
A 5 m/s
B 2.5 m/s
C 10 m/s
D 15 m/s
i think the right answer is A... am I right?
2)
A baby's bath should be at a temperature of 37C. The bath already
contains 10 kg of water at 15C. Approximately how much hot water,
with a temperature of 50C, should be added to achieve the desired
temperature?
A 10 kg
B 15 kg
C 17 kg
D 20 kg
well for this one, I have no clue. please help.. or point out what i should use. thanks!
simo~~
I think for the first one you are considering the velocity of your image from your point of view. Your image approaches the mirror at the same speed as you, but it approaches you at a different speed because you're moving.
For the second one, I think you'd need to use conservation of energy, and the equation E=mcT. Don't worry about c, it cancels.
2) Heat lost by the added hot water = Heat gained by the bath water
mohlam12 said:
1)
image approach you?
A 5 m/s
B 2.5 m/s
C 10 m/s
D 15 m/s
What the hell? The image doesn't approach you at all, it is just a mirror. :confused:
ok, so for the second one, i got the answer C.
what about the first one? :confused:
mohlam12 said:
1)
image approach you?
A 5 m/s
B 2.5 m/s
C 10 m/s
D 15 m/s
No. Figure it out. If you are 10 m from the mirror, how far away is your image? Then when you are 5 m from the mirror, how far away is it?
i'm 10m, the image is 20m away.
i'm 5m away, the image is 10m.
it's moving with the same speed, I'm moving with 5m/s, the image should be moving with 10m/s
  • · Replies 16 ·
  • · Replies 62 ·
