What are the steps to synthesize 1,1,2-trichloroethane using organic compounds?
  • Thread starter Thread starter richievuong
    Compounds Organic
The discussion revolves around the synthesis of 1,1,2-trichloroethane from organic compounds, specifically focusing on the reaction pathways, potential complications, and the underlying chemistry principles involved. The scope includes theoretical approaches to organic synthesis and experimental considerations.
  • Homework-related
  • One participant suggests starting with ethyne and using Cl2 to produce 1,2-dichloroethene, followed by the addition of HCl to yield 1,1,2-trichloroethane.
  • Another participant questions the likelihood of forming 1,1-dichloroethene, arguing that it would require specific conditions such as excess Cl2, which could lead to the formation of 1,1,2,2-chloroethene.
  • A different viewpoint is presented regarding the addition of HCl, with a participant expressing concern about Markovnikov's rule and the possibility of forming 1,2,2-trichloroethane instead of 1,1,2-trichloroethane.
  • One participant notes that both carbons in 1,2-dichloroethene have the same number of hydrogens, suggesting that the addition of HCl could yield the same product regardless of the carbon chosen for the reaction.
  • Concerns are raised about potential polymerization of dichloroethene and the need for careful stoichiometric control during the reactions.
  • Another participant expresses confusion about the term "subsequent polymerization" and seeks recommendations for chemistry textbooks to reinforce their learning.
  • A suggestion is made to ensure that reagents are not added in excess during any step of the synthesis process.
Participants express differing views on the likelihood of forming certain products and the implications of reaction conditions, indicating that multiple competing views remain. The discussion does not reach a consensus on the synthesis pathway or the complications involved.
Participants highlight various assumptions regarding reaction mechanisms, the influence of stoichiometry, and the potential for side reactions, but these aspects remain unresolved within the discussion.
This discussion may be of interest to students studying organic chemistry, particularly those exploring synthesis reactions and the complexities involved in reaction mechanisms.
richievuong
Question: The synthesis of an organic compound typically involves a series of reactions, for example, some substitutions and some additions.
a) Plan a reaction beginning with a hydrocarbon to prepare 1,1,2-trichloroethane
b) What experimental complications might arise in attempting the reactions suggested in part A?
My answer:
a) Well first I used ethyne as my hydrocarbon, added Cl2 to make 1,2-dichloroethene (addition reaction).
Then I would use the 1,2-dichloroethene and add hydrogen chloride (HCl), and it would be an addition reaction that would become 1,1,2-trichloroethane.
Can someone verify my answer ...
b) The only experimental complication I can think of is that during the first step (ethyne + chlorine -> 1,2-dichloroethene) the chlorine may stick to one carbon and make 1,1-dichloroethene...but does that make a difference anyway
well about making 1,1-dichloroethene... it probably won't happen. For if you were to make 1,1 dichloroethene then two other atoms would have to be on the 2 position which isn't likely to happen unless there is excess Cl2 around (but then you get 1,1,2,2 chloroethene). one thing to think about (probably won't matter) is the cis and trans you would get from this reaction.
As for the adding of H-Cl how would you control the chlorine going to the 1st carbon. I believe that this follows Markovnikov orientation and would put the chlorine on the second atom making 1,2,2-trichloroethane
But 1,2-dichloroethene looks like: Cl-CH=CH-Cl
Both carbons contain same number of hydrogens so H-Cl would just have to add itself on either one (wont make a difference cause if you read it forwards and backwards its the same). Markonikovs rule says that "rich get richer" but both carbons have the same amount of hydrogens...
So wouldn't 1,2,2-trichloroethane be the same as 1,1,2-trichloroethane...cause if you are reading 1,2,2-trichloroethane from right to left...
You may have subsequent polymerization with the dichloroethene, also be concerned about rearrangements in general, reactions with water, and reactants should be added with regard to stoichiometry (don't add reagents in excess for any of the steps.
yes, my mistake...must read more carefully...or not do it in my free time at work
Sorry, but I don't quite understand what "subsequent polymerization" really means...
Going off topic a bit: Are there any good chemistry books/text books that are good for reinforcing what I'm learning (I'm doing grade 12 chemistry in high school using the Nelson Chemistry 12 textbook - science.nelson.com)
I live in Canada...
I don't believe that the polymerization would be too much of a problem, however, you should mention that the experiment should be regulated for its stoichiometry, that is, be sure not to add any excess of the reagent for any particular step.
When I was a freshman in college, the text the Chemistry by Raymond Chang, you might want to check out the more recent edition of this text, or you can buy the older editions on ebay from someone who is wanting to sell it for as little as 5.00.
  • · Replies 28 ·
24K
