Calculating Vapor Quality in Tank A: Detailed Solution & Step-by-Step Guide
  • Thread starter Thread starter fishinbs
    Pressure
The discussion focuses on calculating the vapor quality in tank A containing R-12 refrigerant during a transfer process to an evacuated tank B. Initially, tank A has 10% liquid and 90% vapor at 25 degrees C. When the valve between the tanks is opened, the vapor expands from 180L to 380L, maintaining the same pressure. The quality of the vapor in tank A can be determined using the formula x(quality) = (υ – υf) / υfg, where υf is the specific volume of the liquid and υfg is the specific volume of the vapor-liquid mixture.
  • Understanding of thermodynamic properties of refrigerants, specifically R-12.
  • Familiarity with the concept of vapor quality in phase change processes.
  • Knowledge of specific volume calculations for liquids and vapors.
  • Basic principles of adiabatic expansion and saturation states.
  • Study the properties of R-12 refrigerant, including its phase diagram and specific volumes.
  • Learn about the calculations involved in determining vapor quality and specific volume changes.
  • Explore the principles of adiabatic processes and their effects on vapor-liquid mixtures.
  • Investigate the use of thermodynamic tables for refrigerants to find specific volumes and saturation properties.
Engineers, thermodynamics students, and HVAC professionals who are involved in refrigerant management and phase change calculations will benefit from this discussion.
fishinbs
I'm having trouble beginning this problem. It doesn't seem that I have enough information to begin the problem, but I know that can't be the case. Can someone please provide a little direction?
Consider two tanks, A and B, connected by a valve. Each has a volume of 200L, and tank A has R-12 at 25 degrees C, 10% liquid and 90% vapor by volume, while tank B is evacuated. The valve is now opened and saturated vapor flows from A to B until the pressure in B has reached that in A, at which point the valve is closed. This process occurs slowly such that all temperatures stay at 25 degrees C throughout the process. How much has the quality changed in tank A during the process?
EDIT---> Ok, here's what I've got so far:
Before the valve is opened:
specific volume of R-12 liquid is .000763 m3/kg
mass of the R-12 liquid= 20L/.763L/kg= 26.21 kg
specific volume of R-12 vapor is .02685 m3/kg
mass of the R-12 vapor= 180L/26.85L/kg= 6.70 kg
After the valve is opened:
mass of the R-12 vapor= 380L/26.85L/kg= 14.15 kg
What I don't understand is how I determine how much vapor is still in tank A. To determine the quality, I need to know the specific volume of the vapor still in the tank. The formula I have for quality is:
x(quality)= (υ – υf)/ υfg where υf is the specific volume of the liquid and υfg is the specific volume of the vapor-liquid mixture.
Thanks for your help so far. If you could provide any more assistance I would be grateful.
The vapour pressure for a pure liquid is only temperature dependent. If this R-12 can be considered such then the amount of vapour will increase as it expands from 180 L to 380 L in order to keep its pressure the same. Since the expansion is adiabatically the vapour will stay in a state of saturation during all stages of the expansion. My physics intuition tells me that the density of the vapour (and the liquid) should stay the same under such conditions.
  • · Replies 22 ·
