Combining Summing and Difference Op Amps: Troubleshooting v_+
The discussion revolves around troubleshooting a homework problem involving a combination of summing and difference operational amplifiers (op amps). Participants are seeking guidance on how to solve for the voltage at the positive terminal (v_+) and clarify circuit diagram elements.
  • Homework-related
  • One participant expresses difficulty in continuing from their current progress on the problem and seeks direction without having the problem solved for them.
  • Another participant questions the meaning of certain symbols in the circuit diagram, specifically "1" and "Z," and whether they represent static or varying quantities.
  • Some participants suggest writing nodal equations for the inputs to solve for v_+ and v_- and mention the ideal characteristics of op amps that simplify the problem.
  • There is a discussion about the convention of writing numerical values in engineering to avoid confusion.
  • Participants propose setting the voltage at the Vi+ terminal and writing the sum of currents into that node to find v_+. They also discuss the relationship between v_+ and v_- based on ideal op amp properties.
  • One participant presents their calculations and asks for confirmation on their approach, while others provide feedback on their setup and suggest corrections.
  • There is confusion regarding the calculation of currents entering the Vi+ terminal and the proper method for summing currents at nodes with multiple resistors.
  • Participants clarify that the method used applies to both summing and difference amplifiers, indicating the complexity of the problem.
Participants do not reach a consensus on all aspects of the problem, as there are differing interpretations of the circuit elements and methods for calculating currents. Some participants agree on certain approaches while others express confusion or seek clarification.
Participants mention the need to consider the voltage differences across resistors when calculating currents, indicating a reliance on specific assumptions about the circuit configuration. There are unresolved mathematical steps and varying interpretations of the circuit diagram.
Students and individuals studying operational amplifiers, circuit analysis, and those facing similar homework problems in electrical engineering may find this discussion beneficial.
mugzieee
hey guys, i have a HW problem of a combination of a summing and difference op amp. I got the first few steps of the problem, but i don't know how to continue from where i am. I am having a hard time solving for v_+. any help is greatly appreciatd, maybe if you guys can not solve the problem for me, bt direct me towards the right path. thanks in advance. i have attached a scanned image of my work.
I'm having a little trouble undstanding the circuit diagram. What are the "1" and "Z"? Are they meant to represent static quantities? Or is Z a varying input? Or is Z really a 2, like in 2.0V?
As for solving for V+ and V- and Vout, just write the sum of all currents into the + node is zero and do the same for the - node. Since the opamp is ideal, what simplification does that let you make?
the "1",".25",".75",".67", and "2" are all voltages. are you saying that i should right nodal equations for the inputs? i didnt quite understand what you meant...
Yeah, heck if they're static voltages, then you can solve for Vo directly. Just write the two equations for the V- and V+ inputs and solve for Vo. You didn't answer my quiz question yet about what properties does an ideal opamp have that makes this problem easier...
BTW, in order to avoid confusion, in engineering it is a convention to write those numbers like this:
1.0, 0.25, 0.75, 0.67, 2.0
That helps to identify them as numbers, rather than variables or other things. Also, the preceedinig 0 on the numbers less than 1.0 helps to be sure that people don't miss the decimal point. Especially when writing fast on paper, using this convention will help make your work clearer (to you and to others reading/correcting the work).
IDEAL CHARACTERISTICS:
A_ol=inf
R_i=inf
R_o=0
i_+=0
i_-=0
v_in=v_+ - v_-
v_out=A_ol(v_+ - v_-)
v_+=v_-
but i don't see how any of them would make this problem easier
I was referring to the first two that you listed. Very high gain, and zero input current. That let's you assume that Vin+ = Vin-, and just write the voltage divider equation for the + input. Set the - input voltage to the same, and write the voltage divider equation for the - input, including the Vo term. Then just solve for Vo.
ok so from what i understand from what you said, here is what i have done:
.067/2000 + 2/4000 + -2/4000 + ((2-v_o)/50000) = 1/2000 + 0.25/3000 + 0.75/5000
then i solve for v_o?
does that look correct?
No, or at least I'm not tracking what you are writing.
Start with figuring out the voltage at the Vi+ terminal of the opamp. You should write the sum of the three curents into the Vi+ terminal (in terms like (1.0V - Vi+)/2000, and set that sum equal to zero. Then solve for Vi+. Then set Vi- = Vi+, and write the sum of the four currents into the Vi- node and set that sum to zero. That sum will have one term that looks like (Vo - Vi-)/50000, plus three other terms. The only unknown is Vo, so just solve for it then.
EDIT -- Fixed a typo.
heres another shot:
((1-v_i+)/2000) + ((.25-v_i+)/(3000)) + ((.75-v_i+)/5000)) = 0
v_i+=.7097
v_o-=v_i+
((v_o- - .7097)/(50000)) + ((1-.7097)/(2000)) + ((2-.7097)/(4000)) + ((0-.7097)/(4000))=0
v_o-=-13.81
what confuses me is that why can't the current i_1= 1/2k, i_2=.25/3k, i_3=.75/5k for the currents entering v_i+?
also would the current into the node with the two 4k resistors be 2/4k + 0-v_i-/4k?
Vi+ is not ground, so to find the current through the resistor, you need to take the voltage *difference* across the resistor and divide it by the resistance.
And on your second question, you need to sum all the currents into the node, not just two.
mugzieee said:
heres another shot:
v_i+=.7097
v_o-=v_i+
v_o-=-13.81
This looks good to me. I didn't check the math in the final step, but the equation is set up correctly.
so even though this is a part summer, part difference amplifier, the method we used will apply? anyway, thanks a lot for your help berkeman, this problem was giving me nightmares last night..
