Teaching Myself Anti-Derivatives: A Calc II Homework Challenge
The original poster is attempting to self-learn anti-derivatives and integration in preparation for a Calc II class. They present a problem involving finding the volume of a solid obtained by rotating a region bounded by specific curves around the x-axis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the correct formulation of the volume integral, questioning the use of variables and the setup of the integral. There is exploration of the anti-derivative process and the application of the fundamental theorem of calculus.
Participants are actively engaging with the problem, offering guidance on the correct interpretation of the volume calculation and the use of anti-derivatives. There is recognition of the need to clarify the relationship between the radius and the function being integrated, with some participants suggesting corrections to the original setup.
There are indications of confusion regarding the integration limits and the variables used in the volume formula. The original poster has expressed uncertainty about their understanding of anti-derivatives, which is a key aspect of the problem.
tony873004
I’ve dropped my Calc II class because my Calc I class, which I took at the community college, never covered anti-derivatives, and my Calc II class started off assuming you already knew anti-derivatives and integration.
So now I have the fun task of teaching myself anti-derivatives and integration so I can take Calc II again next semester. So I might as well attempt the problems given as homework to the Calc II class. But unlike the homework, I’m going to choose the odd numbered problems so I can check my answers.
Q. Find the volume of the solid obtained by rotating the region bounded by the given curves about the specified line. [tex] y = x^2 ,\,\,x = 1,\,\,y = 0;\,[/tex]about the x-axis.
After drawing it, I came up with
[tex] \begin{array}{l}<br /> v = \sum\limits_0^1 {\pi r^2 } \Delta x = \pi \sum\limits_0^1 {r^2 } \Delta x \\ <br /> \\ <br /> v = \pi \int\limits_0^1 {r^2 ,\,dx} \\ <br /> \end{array}[/tex]
Now here’s where my lack of anti-derivative skills hurt me. What do I do next? To get the anti-derivative of r squared, do I add 1 to the exponent and divide the whole thing by the new exponent? Should I get [tex] \pi \frac{{r^3 }}{3}[/tex]? If so, how do I apply this new formula to get an answer? My integral goes from 0 to 1. How do I get from here to the final answer of [tex] \pi /5[/tex]?
Remember what an anti derivative is. This will help you check yourself.
example)
[tex]\int x^4 \,\, dx = \frac{1}{5}\,x^5 + C[/tex]
Now differentiate it.
[tex]\frac{d(\int x^4 \,\, dx)}{dx} = \frac{d(\frac{1}{5}\,x^5 + C)}{dx} = \frac{1}{5} \, \left( \frac{d(x^5)}{dx} + \frac{d(C)}{dx}\right) = \frac{1}{5} \, 5x^4 + 0[/tex]
... hmmm I just noticed you put
[tex] v = \pi \int\limits_0^1 {r^2 ,\,dx} [/tex]
Did you mean for the [itex]r^2[/itex]?
To get the volume, I'm adding up all the areas of the slices of the shape. They'll form disks with a thickness of delta x when rotated about the x-axis, so for the area I want to do pi r squared. Since radius of each slice would be y(x), I should have put x2 there instead of r2, especially since I put dx.
[tex]v = \pi \int\limits_0^1 {x^2 ,\,dx}[/tex]
Ok, well:
[tex]\pi \int x^2 \, dx = \pi \frac{x^3}{3} [/itex]<br /> (setting the constant equal to 0)<br /> <br /> [tex]\pi \int_a^b x^2 \, dx = \pi \left( \frac{b^3}{3} - \frac{a^3}{3} \right)[/tex][/tex]
Or maybe I meant
[tex]v = \pi \int\limits_0^1 {(r^2) ,\,dx}[/tex]
give me a few minutes to think about this.
edit ^^ my tex didn't do what I wanted it to do
[tex] \begin{array}{l}<br /> v = \pi \int\limits_0^1 {\left( {x^2 } \right)^2 \,,\,dx} \\ <br /> v = \pi \int\limits_0^1 {x^4 \,,\,dx} \\ <br /> v = \pi \frac{{x^5 }}{5} \\ <br /> v = \frac{{\pi x^5 }}{5} \\ <br /> \end{array}[/tex]
So if I plug in 1 for x, I get the same answer as the back of the book. What would I have done if the integration went from 2 to 3 instead of 0 to 1? Do I subtract these numbers and plug it in the formula?
Let's say you have a general function (that's integrable) [itex]f(x)[/itex]
Let the antiderivative equal [itex]F(x)[/itex].
Thus,
[tex]F(x) = \int f(x) \, dx [/itex]<br /> <br /> [itex]F(x)[/itex] is called an indefinite integral.<br /> <br /> If you were to evaluate this integral (as a definite integral), you would have. <br /> <br /> [tex]\int_a^b f(x) \, dx =F(b) - F(a)[/tex]<br /> <br /> This is the first fundamental http://mathworld.wolfram.com/FirstFundamentalTheoremofCalculus.html" of calculus.<br /> <br /> This answers your question in general.<br /> <br /> But to answer your question specifically.<br /> <br /> You asked, what if I integrate from 2 to 3 instead.<br /> <br /> [tex]\pi \int_2^3 x^4 \, dx[/tex]<br /> <br /> From the first fundamental theorem.<br /> [tex]\int_a^b f(x) \, dx =F(b) - F(a)[/tex]<br /> [tex]a = 2[/tex]<br /> [tex]b = 3[/tex]<br /> [tex]f(x) = x^4[/tex]<br /> <br /> Now we have to find [itex]F(x)[/itex]<br /> [tex]F(x) = \int x^4 \, dx = \frac{x^5}{5} + C[/tex]<br /> <br /> Now plugging in a, b<br /> [tex]F(b) = F(3) = \frac{3^5}{5} + C[/tex]<br /> [tex]F(a) = F(2) = \frac{2^5}{5} + C[/tex]<br /> <br /> Finally [itex]F(b) - F(a)[/itex] is equal to:<br /> [tex]\left(\frac{3^5}{5} + C \right) - \left( \frac{2^5}{5} + C \right)[/tex]<br /> <br /> Notice that the constant is dropped.<br /> Also note that this was multiplied by [itex]\pi[/itex] ![/tex]
Just practice some.
You can check your work with,
http://integrals.wolfram.com/index.jsp
Here is a good free calculus book.
http://ocw.mit.edu/ans7870/resources/Strang/strangtext.htm
You can read up on integrals there.
tony - you're going a bit wrong bringing the r into play.
For solids of revolution, you just need the curves y=f(x).
Sketch these curves first.
You can then apply the formula:
[tex]V=\pi\int_0^1f(x)^2dx[/tex]
Thank you FrogPad for your help and for the links.
And Thanks J77. I figured that out that I needed to replace r with the function that gives me r, and it must be in terms of x.
