Solve Axial Displacement: 80kN Load on Steel Rod Attached to Aluminum Tube
The discussion revolves around calculating the axial displacement of a steel rod attached to an aluminum tube under a tensile load of 80 kN. Participants explore the application of material properties and displacement formulas, focusing on the contributions of both materials to the overall displacement at the end of the rod.
  • Homework-related
  • One participant requests guidance on calculating the displacement and provides initial calculations, indicating a potential error in their results.
  • Another participant suggests using the principle of superposition to account for the displacements of both the steel rod and the aluminum tube, emphasizing the need to apply Hooke's Law for each material.
  • The formula for displacement based on tensile stress and material properties is mentioned, highlighting the importance of unit consistency in calculations.
There is no explicit consensus on the calculations or the approach to the problem, as participants are still discussing and refining their understanding of the displacement contributions from both materials.
Participants have not resolved the discrepancies in their calculations, and there may be missing assumptions regarding the lengths and areas used in the formulas. The discussion does not clarify the initial conditions or the specific geometry of the assembly.
This discussion may be useful for students or professionals interested in mechanics of materials, particularly those dealing with axial loading and displacement calculations in composite structures.
mbaron
Please give me some guidance on this problem. I can attach the figure if it will help.
The assembly shown in the figure consists of an aluminum tube AB having a cross sectional area of 400mm2. A steel rod having a diameter of 10 mm is attached to a rigid collar and passes through the tube. If a tensile load of 80 kN is applied to the rod, determine the displacement of the end C of the rod. Take Est = 200 GPa, Eal = 70 GPa. [ΔL = 4.20 mm]
Here is what I have so far:
[tex]E_al = \frac{\sigma}{\epsilon}[/tex]
[tex]70GPa = \frac{\frac{Force}{Area}}{\frac{\delta_length}{length_0}}[/tex]
[tex]70GPa = \frac{\frac{80KN}{.0004m^2}}{\frac{\delta_length}{.4m}}[/tex]
[tex]\delta_length = \left[ \frac{80KN}{.0004m^2} \right] .4m[/tex]
[tex]\delta_length = 1.1428m[/tex]
The displacement is already to large for the given answer. This does not yet include the displacement of the steel bar.
I attached the image that was provided with the homework problem.
Can you post the picture?
Hello again,
You have a superposition of displacements, which will give you the final the displacement of point C. First you have the displacement of the steel rod due to the tensile stress, and then the displacement of the aluminium tube due to compressive stress.
[tex]\delta_{aluminium} + \delta_{steel} = \delta_{C}[/tex]
Use: (displacement of a prismatic bar based on Hooke's Law)
[tex]\delta = \frac{PL}{EA}[/tex]
Becareful of your units.
Thanks for the response. I worked it out.
-Morgan
15K
