What Charge Must an Oil Droplet Have to Balance Gravity in an Electric Field?
The discussion revolves around a physics problem involving an oil droplet in an electric field. The objective is to determine the charge required for the droplet to balance the gravitational force acting on it. The problem includes parameters such as the droplet's radius, the strength of the electric field, and the density of the oil.
  • Participants discuss the relationship between the electric field strength and the charge on the droplet, as well as the gravitational force acting on the droplet. There are attempts to calculate the gravitational force using density and volume, and questions arise about how to equate the forces from the electric field and gravity.
Some participants have made progress in calculating the forces involved but are seeking clarity on how to connect their findings. There is an ongoing exploration of the relationships between the various quantities involved, and guidance has been offered regarding equating the forces to solve for charge.
Participants are working within the constraints of the problem as presented, including the specific values for the electric field, radius, and density. There is an acknowledgment of the need to relate these quantities without providing explicit equations or solutions.
Magna1
Don't know where to go Get stuck at every corner.
Here it is
"A small droplet of oil of 50^10*-6m radius is sitting inside of an electric field 500^10*3 N/C which is pointing straight up. What must be the charge on the oil droplet so that the electrostatic force cancels out due to gravity? The density of oil is 800kg kg/m^3
I don't know where I am going with this. I used E=kQ/r^2 knowing E as 500^10*3 then igured Q as 138.86^10*-15C. I s this even close.
Thanks
"Learning Never Stops"
Did you just use the radius they supplied? If so, you are overestimating the problem...
Things to note:
(a) They have given you the electric field strength, from which you can directly relate charge to force.
(b) They have given you radius, and density, from which you can calculate the force from gravity.
Equate the two and solve.
and then?
I figured out the F due to Gravity (Fg. I used the E and found the charge on Q. but how do I tie the 2 numbers together? I figured out the Fg by using the density=m/v but once again How do I put the two numbers together?
The force due to gravity equals the force due to the E field. The force due to the E field depends on Q, which is what you are trying to find. Set the forces equal and solve for Q.
So can you give concrete equations to equate with?
