Problem with acceleration & distance/displacement:
  • Thread starter Thread starter AznBoi
    Acceleration
The discussion revolves around a physics problem involving acceleration and distance, specifically calculating the minimum constant acceleration required for a car to stop before hitting a deer. The original poster presents their calculations and expresses confusion over a discrepancy between their answer and the one provided in the textbook.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to convert units and apply a formula to find acceleration but questions the correctness of their method. Other participants suggest checking dimensional analysis and using kinematic equations instead. There is a discussion about the necessity of knowing time and the relevance of constant acceleration in solving the problem.
Participants are actively engaging with the original poster's confusion, offering guidance on the use of kinematic equations and the importance of unit consistency. There is a recognition of the challenges faced by the original poster, particularly regarding the understanding of calculus and physics concepts.
The original poster mentions a lack of textbooks and resources, which may be impacting their understanding of the material. They also express a general struggle with the subject matter, indicating a need for foundational learning in physics.
AznBoi
I have showed my work and gotten an answer but it differs from the actual answer in the back of the book. Thanks for your help!
A driver in a car traveling at a speed of 60mi/h sees a deer 100m away on the road. Calculate the minimum constant acceleration that is necessary for the car to stop without hitting the deer (assuming that the deer does not move in the meantime).
My answer is DIFFERENT from the actual answer:
First I converted 60mi/h into m/s:
(60mi/h) x (1609m/mi) x (1h/3600s) = 26.82 m/s
Then I divided 26.82 by 100m : 100/26.82 = 3.73m/s^2
So it's -3.73m/s^2 because it is slowing down??
Did I do the problem wrong? It seems so short so I think I did.
The acutal answer was -3.6m/s^2 What happened??
This step isn't correct, you can check what your doing by using dimensional analysis - check your units;
[tex]\frac{velocity}{distance} = \frac{m.s^{-1}}{m} = s^{-1} \neq m.s^{-2}[/tex]
You need to use kinematic equations to solve this question. Excellent thread presentation though :smile:
Take care of your units, you don't get acceleration by dividing a distance with a velocity!
Instead, proceed as follows with x for position, v for velocity and a for acceleration:
[tex]\frac{dv}{dt}=a\to\frac{dv}{dt}v=av\to\frac{d}{dt}(\frac{1}{2}v^{2})=\frac{d}{dt}(ax)[/tex]
where I've used the fact that "a" is constant.
Thus, integrating between initial time and the time when x=100 and v=0, you get:
[tex]-\frac{1}{2}(26.82)^{2}=a*100[/tex]
Oh, so is there a proper kinematic equation for every problem??
I don't know which one to use, am I suppose to use the average acceleration one?
a= (delta)v/(delta)t Cause I'm trying to find the average acceleration right? V would be 26.82m/s , but what is the time?? They don't give it.
Btw, we don't have textbooks or anything so I have no book source.
What book would you guys recommend me buying to learn Physics B from the start?
I'm a sophomore and I'm in precal.. so I don't know how to use calculus to solve them and I don't understand many things in PHysics!
There is only ONE kinematic equation, with varying additional info given for any particular problem.
In your case, that additional info is first and foremost that the acceleration is CONSTANT.
Read my previous post.
In particular, you'll see that under the assumption of const. acc., you don't NEED the time in order to solve your problem!
ok I don't really understand any of the equations that you guy put down but I will look at the sources you gave me. Thanks to you both! =]
Physics is very hard.. I mean not only do you need to use algebra but you need to use your head aswell! a lot too. =[ My brain isn't quite expanding.
No problem, if you have any question or need any further help don't hesitate to come back :smile: Stick at the physics though :wink:
[tex]\frac{dv}{dt}=a\to\frac{dv}{dt}v=av\to\frac{d}{dt} (\frac{1}{2}v^{2})=\frac{d}{dt}(ax)[/tex]
I don't get what d- derivative is. I've read about it and it confuses me. Also what are the arrows and how did you get v-velocity to be placed in there.
so how did dv/dt= a -> dv/dt x v?? confusing.. =P
This page may explain the calculus more clearly;
http://hyperphysics.phy-astr.gsu.edu/hbase/acons.html#c2
I understand that this stuff may be a bit overwhelming for a pre calc, I would simply recommend learning the formulae without knowing how to derive them before you reach calc.
ok, I'll see if I can figure it out. Thanks again! :smile:
[tex]\frac{d}{dt}(ax) = \frac{da}{dt}x + a\frac{dx}{dt} = av[/tex], since [tex]\frac{dx}{dt}=v[/tex] and a is constant (so [tex]\frac{da}{dt}=0[/tex]).
  • · Replies 38 ·
  • · Replies 20 ·
