Help Solving Algebra Problem: Find Value of K
  • Thread starter Thread starter ruby_duby
    Algebra Value
The discussion revolves around an algebra problem involving finding the value of K for which the line y=2x+K is a tangent to the curve y=x²-2x-7. Participants explore methods related to tangents and quadratic equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using the completing the square method and the midpoint formula to find the vertex of the parabola. There are attempts to derive K based on the conditions for tangency and the relationship between the line and the curve.
Several participants have offered different approaches to the problem, including setting the equations equal to find points of intersection and analyzing the conditions for a single solution. There is ongoing exploration of the implications of these methods, with some participants questioning the values derived for K.
There is some confusion regarding the calculations leading to the value of K, with participants noting discrepancies in their findings. The discussion reflects a collaborative effort to clarify the algebraic reasoning involved.
ruby_duby
Algebra problem!
there's this question that i was given in my class notes and she wants us to try and solve it but i just don't get it and i need your help please. I think that you have to use completing the square method but I am not sure, but here's the question
Find the value of K for which the line y=2x+K is a tangent to the curve y=x²-2x-7.
please help me it would be much appreciated :smile:
edit: Sorry, what I said before was wrong. Actually, the answer is -11.
okay...in algebra you learn something about stuff like that also.
try to find 2 points on y=x^2-2x-7 that are equdistant from the vertex of the parabola. the roots of the equation would work. use midpoint formula to find the coordonate of the vertex, and plug it in f(x) to find it's y-coordonate.
now that you know the y-coordonate of the vertex, that's the K you want.
y'=2x+k...well the "2x" part is given to you ,meaning that you don't actaully know how to make the x^2 turn into a 2x. Looks like an algebra2/precalc problem so use what i wrote above.
Wait a minute... If you do this then you get K=-8 but K should be -11!
OK, I know how to do this. Let's visualize the given curve and the tangent line. Since you already know the slope of the tangent line, all you have to do to get the equation of the tangent line is to "move" your tangent line (without changing its slope) up or down such that it intersects with the curve. BUT, the tagent line should intersect with the curve only once if it is suppose to be called a "tangent."
Now we know that if curve and the tangent line intersect at a single point then they should have the same y coordinate. So we can set the two equations equal to each other i.e.
[tex]2x + K = x^2 - 2x - 7[/tex]
If we solve for x, we get (using the quadratic equation):
[tex]x = \frac{4 \pm \sqrt{44 + 4K}}{2}[/tex]
Now since we are looking for a single soltion for x (i.e. only one intersection) then the value inside the sqrt should be zero. The only way this is possible is when K = -11. :smile:
ok i kind of understand but how do you get 44 in the quadratic equation
Lets start from the top.
So you have
Bringing everything to one side we get:
[tex]x^2 - 4x - 7 - K = 0[/tex]
or
[tex]x^2 - 4x - (7 + K) = 0[/tex]
This is of the form [itex]ax^2 + bx + c[/itex] where a = 1, b=-4, and c = -(7+K).
Now you know that we can solve these types of equations using the quadratic forumula which says that
[tex]x = \frac{-b \pm \sqrt{b^2 - 4ac}}{2a}[/tex]
Using the particular values for a, b and c we get:
[tex]x = \frac{4 \pm \sqrt{16 + 4(7+K)}}{2}[/tex]
further simplifying we get:
[tex]x = \frac{4 \pm \sqrt{44+4K}}{2}[/tex]
Now the only way we can have a single unique solution for x is when [itex]44+ 4K = 0[/itex] which means that K = -11.
thank you for breaking it down to me i finally understand it at last. thank you i really appreciate your help
  • · Replies 25 ·
