Calculating Power in a Circuit with Resistors - Exam Review Question
  • Thread starter Thread starter samurai
    Circuit Power
The discussion revolves around a circuit problem involving three 100-Ohm resistors, focusing on calculating maximum voltage, power dissipated in each resistor, and total power dissipated. The context is set within an exam review scenario.
  • The original poster attempts to calculate the maximum voltage and power dissipated using formulas related to power, resistance, and current. Some participants question the visibility of the circuit diagram necessary for full understanding.
Participants have provided feedback on the original poster's calculations, with one confirming that the process appears correct. However, there is an ongoing discussion regarding the accessibility of the circuit diagram, which may affect the clarity of the problem.
There is a noted issue with accessing the circuit diagram, which is essential for visualizing the problem setup. This may lead to varying interpretations of the problem among participants.
samurai
The final question of my exam review, I have some answers but I may be completely off...
"[7] Three 100-Ohm resistors are connected as shown below. The maximum power dissipated in anyone resistor is 25W. (a) What is the maximum voltage that can be applied to the terminals a and b? (b) For the voltage determined in part (a), what is the power dissipated in each resistor? (c) What is the total power dissipated?"
http://www.geocities.com/SoHo/Bistro/5601/7.JPG
For part (a) I found current 'I' by using P=R*I^2, which was 25=100*I^2, so I found 'I' to equal I=0.5A. I found the total resistance through the standard series-parallel resitance calculations, which ended up as R-Total=150 Ohms. Plugging 'I' and R into V=IR, I found V to equal 75v for part (a).
For part (b) I used V=IR to find the individual voltage for each resistor, which ended up being 50v for the first resistor and 25v for each of the two parallel resistors. I used that value to determine the current in each resistor, which turned out to be .5A for the first resistor and .25A for the two in parallel. Using these values, I was able to plug into P=R*I^2 to determine the power amounts for each resistor, R1=25W, R2=6.25W, R3=6.25W. Is that the right process, and answers?
In part (c) I simply used the total resistance and the series-wide current and plugged those values into P-total=R*I^2 to find P-total=150*(1/2)^2, which turned out to be P-total=37.5W. This total power value matches with the sum of the power found in each individual resistor found in part (b), which is supposed to happen.
While the answers seem to check out, I'd like to confirm whether or not I did the problem correctly. Any opinions or suggestions?
Thanks for your time and help.
no fig is shown by the link
Originally posted by samurai
[7]...
I was able to view your picture using Netscape, but not IE.
Looks good to me.
using IE, I had to copy and paste the url into the address box.
