Calculate Tractive Effort & Draw-Bar Pull for Locomotive A,B,C
  • Thread starter Thread starter paul9619
    Locomotive
The problem involves calculating the tractive effort and draw-bar pull for a locomotive pulling two trucks, with specific masses and resistance to motion provided. The locomotive accelerates uniformly over a distance, and the participants are exploring the calculations involved in determining the forces at play.
  • Participants discuss the calculation of tractive effort based on total resistance and mass, and the need to consider the combined masses of the trucks when calculating draw-bar pulls. There is also a focus on the acceleration and its implications for the forces involved.
Some participants have confirmed the correctness of the initial calculations regarding tractive effort and acceleration. There is ongoing exploration of the calculations for draw-bar pulls, with guidance provided on how to account for the masses and resistances of the trucks.
Participants are working within the constraints of the problem as presented, including specific masses, resistance values, and the uniform acceleration assumption. There is an emphasis on ensuring all forces are accounted for in the calculations.
paul9619
Hi all,
Another teaser that I have been attempting is the following:
A Locomotive (A) pulls two tracks (B) and (C). The masses of A,B & C are 80, 25 and 20 tonne respectively. The train starts from rest and accelerates uniformally to cover 2KM in 8 minutes. Assume the resistance to motion of the locomotive and the trucks is 200N/tonne
1. Calculate the tractive effort developed by the locomotive A.
I have used the formula: Tractive Effort = Total resistance to motion (R) + Mass x Acceleration.
The total resistance to motion is 200/N tonne x (80+25+20) = 25KN
The mass is 125 Tonne
The acceleration I have as 0.01736111 m/s using s=ut+1/2at^2.
Therefore I have the tractive effort as 27.17K Newtons.
Is this right?
2. Calculate the draw-bar pull between A and B
3. Calculate the draw bar pull between B & C
I am struggling with 2 and 3. Could anyone give me any pointers??
1. Your reasoning is correct. I have not checked your numbers, but I suppose they are OK.
2. Remember that A must pull the combined masses of B and C.
3. The draw bar between B and C must pull the mass of C.
The acceleration of 0.01736111 m/s2 is correct assuming that locomotive and trucks are accelerating uniformly.
As SGT mentioned, the drawbar between A and B has the masses and resistance of B and C pulling on it, and between B and C, the drawbar only pulls C.
Ok taking this into consideration I have done the following.
Resistance to motion = 25 tonne x 200 N/tonne = 5000N for truck b
= 20 tonne x 200 N/tonne = 4000N for truck c
Therefore total resistance to motion is 9000N.
Force required to move B & C = Acceleration x mass = 781.25N
Therefore the pull between A and B is 9000N + 781.25 = 9781.25N
Does this seem right??
Obviously for the pull between B & C it will be the same precedure but just taking into account the resistance & motion of C.
It's right.
10K
