| Thread Closed |
Hooke's law with spring |
Share Thread | Thread Tools |
| Sep28-06, 07:57 AM | #1 |
When a 4.00 kg object is hung vertically on a certain light spring that obeys Hooke's law, the spring stretches 2.50 cm. (a)If the object is replaced with one of mass 1.50 kg, how far will the spring stretch?
b) How much work must an external agent do (i.e. a force coming from the 'environment'), to stretch the same spring 4.00 cm from its unstretched position? For a) I used the equation F= -kx to solve for k. F=ma so ma=-kx since the object is vertical. (4.00)(-9.8)= -k(.025m) k= 1568 N/m then I plugged it back in to solve for x ma= -kx (1.5)(-9.8)= -1568x x= 0.00938 m Is there something I'm doing wrong? b) W= 1/2k(xi)^2 - 1/2k(xf)^2 W= 0-1/2(1568)(.04m)^2 = -1.25 J The homework says this is wrong but I can't figure out what else to do? Any help would be appreciated. |
| Sep28-06, 10:14 AM | #2 |
Recognitions:
[tex](1.50)/(4.00)*(2.5 cm)=0.938 cm[/tex] However, your method gives the value for k, which you need in the next exercise. |
| Sep28-06, 01:29 PM | #3 |
Thanks for responding. I'm using a computer program for this homework and it's telling me that both answers are wrong. This is after I saw what you wrote. So I'm just double checking to make sure that there is absolutely nothing wrong with this. It could be a glitch in the program.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Hooke's law with spring
| Ideal Spring and Real Spring Difference? (Hooke's Law) | Introductory Physics Homework | 10 | ||
| [SOLVED] Spring Hooke's law | Advanced Physics Homework | 12 | ||
| Hooke's law | Introductory Physics Homework | 1 | ||
| difference between hooke's law and the work done in a spring? | Introductory Physics Homework | 3 | ||
| Hooke's law with a spring | Introductory Physics Homework | 3 | ||
