Solve Resistance Problem 27: Finding Resistance of A | Problem 28 Solution
  • Thread starter Thread starter mustang
    Resistance
The discussion focuses on solving resistance problems involving two resistors, A and B, connected in series and parallel configurations with a 12 V battery. For Problem 27, the potential difference across resistor A is 6.7 V, allowing the calculation of its resistance using Ohm's Law and the series resistance formula Rtotal = R1 + R2. The current in resistor B is given as 1.6 A when connected in parallel. Problem 28 remains unsolved due to a lack of specific details, but general strategies for solving resistance problems are provided, emphasizing the importance of circuit type and relevant formulas.
  • Understanding of Ohm's Law (V = IR)
  • Knowledge of series and parallel circuit configurations
  • Familiarity with resistance formulas: Rtotal = R1 + R2 and 1/Rtotal = 1/R1 + 1/R2
  • Basic skills in circuit analysis
  • Practice calculating resistance in series circuits using Rtotal = R1 + R2
  • Learn to analyze parallel circuits with the formula 1/Rtotal = 1/R1 + 1/R2
  • Explore advanced applications of Ohm's Law in complex circuits
  • Review common resistance problems and solutions for better understanding
Students, educators, and anyone studying electrical engineering concepts, particularly those focusing on circuit analysis and resistance calculations.
mustang
Problem 27.
Two resistors, A and B, are connected in series to
a 12 V battery. A voltmeter
connected across resistor A measures a potential
difference of 6.7 V. When the two resistors are connected in parallel
across the 12 V battery, the current in B is found to be 1.6 A.
Find the resistance of A.
On problem 28 how does it get solve? I'm stumped.
Here's a hint: when resistors are connected in parallel, the voltage measured across anyone resistor will equal the source voltage. In this case, 12V.
To solve problem 27, we can use the formula for total resistance in a series circuit, which is Rtotal = R1 + R2. We know that the total voltage is 12 V and the potential difference across resistor A is 6.7 V. Using Ohm's Law (V = IR), we can find the current in resistor A, which is 6.7 V / R1. We can then substitute this value into the formula for total resistance, along with the given current in resistor B (1.6 A), to solve for the resistance of A.
As for problem 28, it is difficult to provide a solution without knowing the specific problem. However, some general steps to solve a resistance problem would be to first determine the type of circuit (series or parallel), then use the appropriate formula (series: Rtotal = R1 + R2, parallel: 1/Rtotal = 1/R1 + 1/R2) to find the total resistance. From there, you can use Ohm's Law (V = IR) to find the current in each resistor and solve for any missing values. If you are still stumped, it may be helpful to review the principles of series and parallel circuits and practice solving similar problems.
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 24 ·
