This universe would expand right?
  • Context: Graduate
  • Thread starter Thread starter aquabug918
    Universe
The discussion revolves around the implications of converting mass into radiation within the framework of Einstein's static universe model. Participants explore the effects on the universe's expansion or contraction, considering various theoretical perspectives and equations related to cosmology.
  • Some participants suggest that converting mass into radiation would decrease density, potentially leading to expansion, while questioning if the cosmological constant would remain unchanged.
  • Others argue that Einstein's static model is inherently unstable, and that the conversion of mass to energy would not necessarily lead to expansion or contraction, as both forms would exert similar gravitational effects.
  • One participant posits that radiation contributes more significantly to pressure in Einstein's equations, which could lead to contraction if all matter were converted to radiation.
  • Another viewpoint emphasizes that in a flat universe without dark energy, the expansion scale factor would change from \( R(t) \propto t^{2/3} \) to \( R(t) \propto t^{1/2} \) if all matter turned into radiation.
  • Further contributions clarify that the addition of radiation pressure could destabilize the static model, leading to a tendency towards collapse rather than expansion.
  • Some participants reference historical theories, such as those by Eddington and Lemaitre, discussing how the conversion of matter to radiation might influence the universe's pressure and expansion dynamics.
  • One participant argues that mass-energy equivalence means the conversion would not fundamentally alter the physics, although density might play a role.
  • Another participant describes a scenario involving annihilation of matter and anti-matter, resulting in radiation and pressure changes that would affect the expansion rate.
Participants express differing views on the consequences of mass-to-radiation conversion, with no consensus reached on whether this would lead to expansion or contraction. Multiple competing perspectives remain throughout the discussion.
Participants reference various cosmological models and equations, highlighting the complexity of the relationships between mass, energy, pressure, and expansion dynamics. Some assumptions and definitions remain implicit, and the discussion does not resolve the mathematical implications of these conversions.
aquabug918
In Einstein's view of a static universe what would happen if some mass turned into radiation?
I am thinking that since the density would decrease then the universe would expand since the cosmological constant would stay the same. Would it change?
Space news on Phys.org
Einstein's static model was unstable, a small perturbation towards either collapse or expansion would be magnified into full collapse or expansion.
However the conversion of mass into energy would not in itself achieve this as both would have an equal effect on the cosmological gravitational field.
Garth
Thank you very much! I still have a lot to learn but this is very interesting! Thanks again.
I've a feeling that since radiation has a contribution to the pressure term in Einstein's equation, the radiation would have a greater effect than the corresponding amount of matter, and so the universe would contract.
Agreed:-
if all the matter turned into radiation, and if the universe were spatially flat without DE or a cosmological constant then the expansion scale factor
[itex]R(t) \propto t^{2/3}[/itex] becomes
[itex]R(t) \propto t^{1/2}[/itex]
Garth
Garth said:
Agreed:-
Wouldn't that mean you disagree? Neither case corresponds to contraction...
For clarification:
I was originally talking about the unstable Einstein static model, which does have a cosmological constant and is spatially closed i.e. geometrically spherical, but then used a simple flat Friedmann expanding model to show that the addition of pressure - radiation pressure - causes that expansion to decelerate more quickly.
The inference being that the addition of pressure would cause the Einstein static model instability to tend towards collapse.
Garth
1 don't see how it would make any difference in GR. Mass and energy are interchangeable. Perhaps density would be a factor, but I doubt it would change physics as we know it. The photon v baryon ratio would not be affected, IMO.
Chronos take the standard flat non-CC expanding Friedmann universe as an example, the Einstein-de Sitter universe, as I did above.
Imagine its density is made up of dust particles, zero pressure, composed of equal numbers and masses of individual matter and anti-matter particles.
The average cosmological density is the critical density
[tex]\rho = \frac{3H_0^2}{8\pi G}[/tex]
and the expansion rate will be
[tex]R(t) \propto t^{2/3}.[/tex]
Now let the particles collide (slowly) and annihilate each other producing a radiation bath of gamma rays.
The matter density will be converted into an equal energy density of radiation but now there will also be pressure of
p = 1/3 rho c2 (note: for some reason my tex gets screwed up here)
and the universe will expand as
[tex]R(t) \propto t^{1/2}.[/tex]
Garth
The reason I picked up on this was that I've just read The Expanding Universe by Sir Arthur Eddington. His idea was that the universe began as Einstein's static universe but was tipped into expansion. On p51 he mentions that the conversion of matter into radiation will induce contraction. His theory is based on a rather obscure argument by Lemaitre that the condensation of parts of the universe will not directly tip the scales one way or the other, but will result in an overall reduction in pressure. Eddington says (p53)
Its effect is therefore the opposite to that of conversion of material mass into radiation, and it tends to make the universe expand
Another way to see this is the following. A static universe means [itex]\dot a = \ddot a = 0[/itex], a condition that is reached with the help of a cosmological constant term [itex]\Lambda[/itex]. According to the second Friedmann equation this, in turn, means that:
[tex]\frac{\ddot a}{a} = - \frac{4 \pi G}{3} (\rho + 3p) + \frac{\Lambda}{3} = 0[/tex]
If matter is converted to radiation, the [itex]p[/itex] term converts from zero (non-relativistic matter exerts no pressure) to some positive value, making [itex]\ddot a[/itex] negative, different from zero. Note that at this initial instant of time when the conversion takes place, t0, it still holds [itex]\dot a = 0[/itex]. The [itex]\rho[/itex] and [itex]\Lambda[/itex] terms remain unchanged at t0.
Consulting page 45 of my 1940 edition (Pelican Books) of the 1932 Eddington's "The Expanding Universe"...
The problem they had in the early days was an age problem: their evaluation of Hubble's constant was too high, which inferred the universe was younger (at 1.9 Gyr.) than the Earth within it (at 4.6 Gyr.)!
The Eddington-Lemaitre suggestion was one model that tried to resolve this problem, in which the universe had a cosmological constant and had been almost static, remaining as such while large scale structure formed, right down to the scale of Earth sized planets.
In order to produce the expanding universe we now observe this unstable equilibrium had to have been disturbed about 1.9 Gyrs. ago into a runaway expansion.
What might have caused this expansion rather than a contraction?
The problem was that as stars etc formed in this static phase it might be expected that the radiation content of the universe would increase, as a result of this extra radiation flux, and cause a contraction instead of an expansion. Hence their need for a rather complicated and unconvincing process utilising "an empty crack all round" condensations of matter to reduce the overall pressure.
As we now know Hubble's constant is actually an OOM smaller than their estimate and the present estimation of the age of the universe (13.9 Gyrs.) leaves plenty of time for the Earth to form. Whether the present standard model contains another Age Problem remains to be seen...
Garth
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 17 ·
