Thread Closed
Hooke's law with a spring
Share Thread Thread Tools
Oct2-06, 05:46 PM   #1
When a 4.00 kg object is hung vertically on a certain light spring that obeys Hooke's law, the spring stretches 2.5 cm.
(a) If the object is replaced with one of mass 1.45 kg, how far will the spring stretch?
F=ma
-ma=-kx
-(4)(9.8)=-k(0.025)
k=1568
-(1.5)(9.8)= -1568x
x=0.00938m
I keep being told that this is wrong and yet I have not been able to figure out where I went wrong. Can someone point out what the problem is.
b) how much work must an external agent do (i.e. a force coming from the 'environment'), to stretch the same spring 4.9 cm from its unstretched position?
Here I used k=1568 and W=1/2kxi^2- 1/2kxf^2
=1/2(1568)(0)^2-1/2(1568)(0.049)^2
W=1.25J or -1.25 J
Once again I'm being told that this is wrong and would like for someone to point out the problem.
Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Oct2-06, 06:52 PM   #2
Mentor
Quote by bearhug
F=ma
-ma=-kx
-(4)(9.8)=-k(0.025)
k=1568
-(1.5)(9.8)= -1568x
x=0.00938m
I don't see any fundamental problem here (except for your misuse of "F = ma"--see below). But why did you use 1.5 instead of the given 1.45 kg? (You can also solve this using ratios.)
One thing to point out: You are not using Newton's 2nd law here (F = ma), but you are using Hooke's law (F = kx). In this case, the F is the force that is stretching the spring--which is the weight of the hanging mass: w = mg.
W=1.25J or -1.25 J
I only see two problems: (1) Your signs are off. Note that change in spring energy (or anything) is always final - initial. The work done is positive. (2) Check your arithmetic.
Oct2-06, 07:03 PM   #3
Quote by Doc Al
I don't see any fundamental problem here. But why did you use 1.5 instead of the given 1.45 kg? (You can also solve this using ratios.)
technicaly hooke's law is F= -kx and the work done by a spring is infact i-f.
Oct2-06, 07:12 PM   #4
Mentor
Quote by BishopUser
True, but here we are finding the work done by an external agent in stretching the spring--which equals the change in the spring's energy--which is "final energy - initial energy". (The minus sign in Hooke's law tells you the direction of the spring's restoring force, which is opposite to the force applied by the external agent.)
Thread Closed
Thread Tools
Similar Threads for: Hooke's law with a spring
Thread Forum Replies
Ideal Spring and Real Spring Difference? (Hooke's Law) Introductory Physics Homework 10
[SOLVED] Spring Hooke's law Advanced Physics Homework 12
Hooke's law Introductory Physics Homework 1
difference between hooke's law and the work done in a spring? Introductory Physics Homework 3
Hooke's law with spring Introductory Physics Homework 2
