Spring constant and temperature
The discussion revolves around the potential relationship between the spring constant of a spring and the temperature of that spring. Participants explore theoretical implications, experimental observations, and material properties, particularly focusing on polymers and elastic materials.
  • Experimental/applied
  • Some participants suggest that the spring constant is not directly related to temperature, noting that Young's modulus typically changes with temperature, which can affect the spring constant.
  • Others argue that for polymers, the spring constant can be derived from statistical methods, indicating a proportional relationship with temperature.
  • A proposed experiment suggests that cooling a rubber material decreases its elasticity, implying an inverse relationship between spring constant and temperature.
Participants express differing views on the relationship between spring constant and temperature, with no consensus reached. Some believe there is a direct relationship in certain materials, while others assert that the relationship is not straightforward and can vary based on material properties.
Limitations include the dependence on specific material types (e.g., polymers vs. metals) and the need for further empirical evidence to support claims about the relationship between spring constant and temperature.
adam.musial
Hey!
Does anybody know any possible relationship between spring constant and the temperature of that spring??
Science news on Phys.org
THe spring constant ,k , is a force constant for a particular spring. The temperature is a measurement of the average kinetice energy of the molecules of the spring. THey are not directly related.
For most things, the "Young's modulus" of the material will change with the temperature, most things getting more easily stretched as temperature increases. Therefore the spring constant will get smaller for most things as the temperature goes up.
Somethings get stiffer as temperature increases, so there is no absolute rule that associates these two characteristics.
They ARE related! The spring is not an ordinary spring but polymers. You can derive Hook's Law by applying statistical methods and take the short displacement limit, the coeff. in the out front is obviously the spring const. and it is proportional to the temperature! I don't know why?!
We can perform a simple experiment to know about the relationship between spring constant and temperature :
STEP1 : Take a rubber and decrease its temperature.(keep it in your refrigerator)
STEP2 : Now drop it on the floor to check its elasticity.
If compared with a rubber at room temperature
the elasticity of the cooled rubber will be less than the rubber at room temperature
it simply means that when the temp is decreased the elasticity is also decreased
the rubber behaves like spring as both are elastic materials
spring constant k is inversly propotional to temperature.
  • · Replies 18 ·
  • · Replies 17 ·
