| Thread Closed |
Volume of a solid |
Share Thread | Thread Tools |
| Jan29-04, 07:40 PM | #1 |
Volume of a solid
The base of a solid is the region bounded by the graphs of x=y^2 and x=4. "Each cross section is perpendicular to the x-axis is a triangle of altitude 2." Find the volume of the solid.
That was how it was worded, I'm guessing it meant Each cross section perpendicular to the x-axis is a triangle of altitude 2? Assuming that's what it says. How are these problems tackled? The addition of the quoted sentence confuses me a tad bit on what direction to head. |
| Jan29-04, 10:15 PM | #2 |
So after looking at it some more, I got:
Int{0 to 4} Sqrt(3)/4 * (4 - Sqrt(x))^2 dx ? Hrmm.. ok, I just noticed I didn't use the altitude... |
| Jan30-04, 07:28 AM | #3 |
Since the area of a triangle is (1/2)h*b and h= 2, you only need to calculate b. The cross section is perpendicular to the x-axis so the base is the y distance. y, for specific x, ranges from x2 up to 4 so the distance is b= 4-x2. That is, the area of such a triangle is (1/2)(4-x2)(2)= 4- x2. Imagining each cross section as an infinitesmally this slab, of thickness dx (since the thickness, perpendicular to the plane, is in the x-direction), the "volume" of each slab is (4- x2)dx. Putting all of the "slabs" together, the total volume is [tex]\int_0^4(4-x^2)dx[/tex] I have absolutely no idea where you got all those square roots! |
| Feb1-04, 01:24 PM | #4 |
Volume of a solid
shouldn't it be composed as a triple integral since you are dealing with a solid? or did I not read the problem correctly?
| Feb1-04, 01:27 PM | #5 |
this helped me a lot when I was in calc...
making a graphical representation (even if it is 3 dimetions) can help a lot. |
| Feb2-04, 05:59 PM | #6 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Volume of a solid
| volume of solid:( | Calculus | 5 | ||
| volume of the solid | Introductory Physics Homework | 11 | ||
| Volume of Solid | Calculus | 8 | ||
| volume of a solid | General Math | 4 | ||
| Volume of a solid | General Math | 1 | ||
