What Happens When a Copper Square is Heated Uniformly?
  • Thread starter Thread starter azn_enigma
When a copper square is heated uniformly, it expands uniformly, resulting in a square with a larger area. The discussion highlights the confusion regarding whether the question pertains to the heated square itself or the hole left in the copper sheet. Participants predominantly agree that the heated square increases in size, confirming option (a) as the correct answer.
  • Understanding of thermal expansion principles
  • Basic knowledge of material properties, specifically copper
  • Familiarity with geometric concepts related to area
  • Awareness of the implications of heating on solid materials
  • Research the principles of thermal expansion in metals
  • Explore the properties of copper and its behavior under heat
  • Study geometric transformations and their effects on area
  • Investigate the practical applications of thermal expansion in engineering
Students in physics or engineering, materials scientists, and anyone interested in the effects of heat on solid materials.
azn_enigma
A square is cut out of a copper sheet. The square is heated uniformly. As a result, it turns into
a) a square with a larger area
b a square with a smaller area
c a rectangle with a larger area
d a rectangle with a smaller area
i fink its a =(
wut do u guys think?
I agree with a. A square heated uniformly should just get uniformly larger.
Well now, wait a minute. Do they mean the copper square that got cut out, or the hole left in the sheet when the square was cut out? If the latter, then I'm not sure what the answer is...
