Time Elapsed between Light Emission and Absorption at Different Frames
The discussion revolves around the calculation of the time elapsed between the emission and absorption of light in different reference frames, specifically in the context of special relativity. The original poster presents a scenario involving a flash of light emitted from point O and reabsorbed at point P, with the challenge of determining the time tau' in a moving frame S'. The problem incorporates concepts such as length contraction and the geometry of light propagation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using length contraction to find coordinates in the moving frame and explore the relationship between distances traveled by the light pulse and the moving receiver. There are inquiries about the application of Pythagorean theorem and the setup of quadratic equations to solve for tau'. Some participants seek clarification on specific steps and algebraic manipulations involved in deriving the final expression for tau'.
The discussion is active, with participants providing insights and guidance on the mathematical approach. Several interpretations of the problem are being explored, particularly regarding the application of length contraction and the setup of equations. While there is no explicit consensus, the dialogue indicates a productive exploration of the problem.
Participants note the importance of correctly applying relativistic effects and the need to combine terms effectively in the algebraic expressions. There is a sense of urgency expressed by one participant regarding the completion of the problem, indicating imposed homework constraints.
byerly100
A flash of light is emitted at point O and is later reabsorbed at point P. In frame S, the line OP has a length l and makes an angle theta with the x axis. In a frame S' moving relative to S with a constant velocity v along the x axis:
How much time tau' elapses between emission and absorption of the light?
The answer is (1-betacos(theta))gamma*l/c, where beta=v/c
How does one get this answer?
It took some effort, but I managed to do this. I used length contraction in the x direction to figure out the coordinates of P in S' when the pulse is emitet. Since S' is moving relative to points O and P in S, the pulse receiver is moving through S' toward the y' axis a distance v*tau' as the light pulse is moving a distance c*tau'. It's just vector addition to find the distance the pulse travels to the receiver. You get a quadratic equation for tau' that is most easily handled in terms of the combination c*tau'/gamma. Solve the quadratic and simplify and you've got it.
Could you give some more detail on "length contraction in the x direction to figure out the coordinates of P in S' when the pulse is" emitted?
Code:
[tex]l= l_p/gamma[/tex]
Also,
(c*tau')^2=(v*tau')^2+(x)^2 ?...
If O is the origin, then the coordinates of P in S are
x = l*cos(theta)
y = l*sin(theta)
Let the origins of S and S' coincide when the pulse is emitted. Then the coordinates of P in S' are found by contracting in the direction of motion
x' = x/gamma
y' = y
You could use Pythagoras to find the distance from O to P in S', but the light pulse will not go that far because P is moving through S' with speed v. You need to figure out how far it is from the origin to where the light pulse intercepts P. That will be at
(x' - v*tau', y') = (l*cos(theta)/gamma - v*tau', l*sin(theta))
Use Pythagoras to find the distance from O this point and set it equal to c*tau'
[(l*cos(theta)/gamma - v*tau')^2 + (l*sin(theta))^2 = d^2 = (c*tau')^2
[(l*cos(theta)/gamma - v*tau')^2 + (l*sin(theta))^2]^(1/2)/c=tau'
"most easily handled in terms of the combination c*tau'/gamma"
byerly100 said:
Do I need to solve this equation for something, like x', y'?
(x', y') = (l*cos(theta)/gamma - v*tau' + v*tau', l*sin(theta)) ?
(x', y') = (l*cos(theta)/gamma, l*sin(theta)) ?
(l*cos(theta)/gamma)^2+ (l*sin(theta))^2 = d^2 = (c*tau')^2 ?
[(l*cos(theta)/gamma)^2+ (l*sin(theta))^2]^(1/2)/[c]= tau'
That must not be right since v is in the answer.
"You get a quadratic equation for tau' that is most easily handled in terms of the combination c*tau'/gamma. Solve the quadratic and simplify and you've got it."
(l*cos(theta)/gamma - v*tau')^2 + (l*sin(theta))^2 = d^2 = (c*tau')^2 ?
[(l*cos(theta)/gamma - v*tau')^2 + (l*sin(theta))^2]^(1/2)/c=tau' ?
The blue is all you need, and then some algebra skills and one well known trig identity.
byerly100 said:
http://www.mathwizz.com/algebra/help/help32.htm
http://en.wikipedia.org/wiki/Trigonometric_identity
Somehow the sin is eliminated...
cos^2(a) + sin^2(a) = 1?
cos^2(a) = 1 - sin^2(a) ? (maybe not)
http://en.wikipedia.org/wiki/Trigonometric_identity#Power-reduction_formulae ?
(The answer is (1-(v/c)cos(theta))gamma*l/c).
What kind of algebra skills?
Should I FOIL (expand) (l*cos(theta)/gamma - v*tau')^2 ?
l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + v^2tau'^2 ?
whole equation =
l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + v^2tau'^2 +
l^2sin^2(theta) ?
*I need to have this finished tomorrow so I should finish it tonight.
The sin^2 = 1-cos^2 is the first step after squaring terms. Combine the cos^2 terms and you will have a factor of 1-1/gamma^2 which is beta^2. Replace any v with beta*c and you should have something in the form of a quadratic
0 = x^2 + bx + c where b = 2*l*beta*cos(theta), c = l^2[1-beta^2cos(theta)^2] and x = c*tau'/gamma.
Use the quadratic formula. The beta*cos(theta) contributions to the discriminant cancel leaving you with l*sqrt(1). Only the + root is kept. Solve for tau' and your done.
byerly100 said:
Did "squaring" include FOILing or just having a ^2?
Yes. FOIL it
byerly100 said:
[l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + v^2tau'^2 + l^2sin^2(theta)]^(1/2)/c= tau'
sin^2 = 1-cos^2
square the whole thing to get rid of the ^(1/2) and combine the v^2tau'^2with the c^2tau'^2 into a term with a gamma^2
use the sin^2 = 1-cos^2 and combine the cos^2 terms
byerly100 said:
[l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + v^2tau'^2 + l^2sin^2(theta)]/c^2=tau'^2
[l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + v^2tau'^2 + l^2sin^2(theta)]=c^2tau'^2
Keep going :!)
[l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + l^2sin^2(theta)]=c^2tau'^2 - v^2tau'^2 = c^2tau'^2/gamma^2
byerly100 said:
sin^2 = 1-cos^2
[l^2cos^2(theta)/gamma^2 - 2v*tau'*l*cos(theta)/gamma + l^2{1-cos^2(theta)}]= c^2tau'^2/gamma^2
I'm not sure how you said c^2tau'^2 - v^2tau'^2 = c^2tau'^2/gamma^2.
I think I'm supposed to combine the cos^2 terms now.
l^2cos^2(theta) - 2v*tau'*l*cos(theta)gamma + [l^2{1-cos^2(theta)}]gamma= c^2tau'^2
c^2tau'^2 - v^2tau'^2 = (c^2 - v^2)tau'^2 = c^2(1 - v^2/c^2)tau'^2= c^2tau'^2/gamma^2.
Replace that v in the linear term with beta*c
l^2cos^2(theta) - 2beta*c*tau'*l*cos(theta)gamma + [l^2{1-cos^2(theta)}]gamma= c^2tau'^2
l^2cos^2(theta) - 2beta*c*tau'*l*cos(theta)gamma + [{l^2-l^2cos^2(theta)}]gamma= c^2tau'^2
What do I need to do to get the below?
At some point, I need to combine the cos^2 terms.
"quadratic
0 = x^2 + bx + c where b = 2*l*beta*cos(theta), c = l^2[1-beta^2cos(theta)^2] and x = c*tau'/gamma. (-> 0= (c*tau'/gamma)^2 + 2*l*beta*cos(theta)(c*tau'/gamma) + l^2[1-beta^2cos(theta)^2] )
a=1?
Use the quadratic formula."
*I still need to get the above but I'm going to insert things into the quadratic formula now.
http://mathworld.wolfram.com/images/equations/QuadraticEquation/equation5.gif
c*tau'/gamma= (-2*l*beta*cos(theta)) +/- [(2*l*beta*cos(theta))^2-4(1){l^2[1-beta^2cos(theta)^2]}]^(1/2)) / (2(1))
You said, "The beta*cos(theta) contributions to the discriminant cancel leaving you with l*sqrt(1). Only the + root is kept. Solve for tau' and your done." ...?
c*tau'/gamma = (-2*l*beta*cos(theta)) + l ?
Again, the answer is tau' = (1-betacos(theta))gamma*l/c
When the file appears, you can see it all. Check my work!
I can't get this LaTeX stuff to appear either
Yes you do. They are both part of the "c" term
byerly100 said:
I was wondering exactly where you started in the file.
It looks like you started around https://www.physicsforums.com/showpost.php?p=1129304&postcount=6.
I started by saying the distance from the origin to the position where the pulse is received is c*tau'. The unlabeled diagram (in S') shows this as the red arrow. The black arrow is v*tau'. The black slanted line is the separation of O and P when the pulse leaves O. Its components are l*cos(theta) and l*sin(theta). The radical is the sum of the squares of the components of c*tau'
  • · Replies 143 ·
10K
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 23 ·
