Calculate Absolute Pressure with Pump, Height, Density
  • Thread starter Thread starter mindhater
The absolute pressure provided by the pump in the drinking fountain scenario is calculated to be 1,003,125 Pa, or approximately 10 atm. This calculation utilizes Bernoulli's equation and incorporates the height of the pump (90 m), the density of water (1000 kg/m³), and the acceleration due to gravity (9.8 m/s²). The formula applied is (g)(h)(density) + atmospheric pressure, where atmospheric pressure is approximately 101,325 Pa. The conversion of measurements into meters is essential for accurate calculations.
  • Understanding of Bernoulli's equation
  • Knowledge of fluid dynamics concepts
  • Ability to perform unit conversions (cm to m)
  • Familiarity with basic physics principles (density, gravity)
  • Study Bernoulli's equation in detail
  • Learn about fluid dynamics applications in engineering
  • Explore the Pythagorean theorem for practical applications
  • Research atmospheric pressure effects on fluid systems
Students in physics or engineering, fluid dynamics enthusiasts, and professionals involved in pump design or hydraulic systems will benefit from this discussion.
mindhater
The drinking fountain outside your class shoots water 15 cm straight up in the air from a nozzle diameter of .58 cm. The pump at the base of the unit (90 m below the nozzle) pushes water into a 2.2 cm diameter supply pipe that goes up the nozzle. What is the absolute pressure provided by the pump?
i assume, it's calculate the pressure using (g)(h)(density) + atm pressure = absolute pressure
but I'm not sure...so if there's ne advice or something I'm missing...thx
This one can be solved using Bernoulli's equation. There might be easier wayto do it, but this how I'd break it down (I suppose you are familiar the equation).
On the left side, there are pressure (supplied by the pump), velocity ( you can calculate by recognizing that [itex]A_1*v_1=A_2*v_2[/itex]) and potential energy ( it makes sense to use this point as zero point for pot.energy). On the right side you have pressure again, velocity and potential energy.
There shouldn't be any unknowns remaining...
You are correct in your approach to calculating absolute pressure using the formula (g)(h)(density) + atmospheric pressure. In this case, we can assume that the density of water is 1000 kg/m^3 and the acceleration due to gravity (g) is 9.8 m/s^2. We also need to take into account the atmospheric pressure, which is typically around 101,325 Pa.
First, we need to convert the given measurements into meters to match the units of our formula. The height of the pump is 90 m, the nozzle diameter is 0.58 cm (0.0058 m), and the supply pipe diameter is 2.2 cm (0.022 m).
Next, we can calculate the height (h) from the base of the pump to the nozzle using the Pythagorean theorem: h = √(90^2 + 0.0058^2) = 90.0005 m.
Now, we can plug in all the values into our formula: (9.8 m/s^2)(90.0005 m)(1000 kg/m^3) + 101,325 Pa = 901,800 Pa + 101,325 Pa = 1,003,125 Pa.
Therefore, the absolute pressure provided by the pump is 1,003,125 Pa, or approximately 10 atm. This pressure is the combined effect of the pump pushing water up the supply pipe and the natural atmospheric pressure pushing down on the water.
I hope this helps clarify the process for calculating absolute pressure in this scenario. If you have any further questions or concerns, please let me know.
  • · Replies 32 ·
13K
  • · Replies 23 ·
  • · Replies 24 ·
19K
